Thanks! Gone in 60 minutes - posts.
CU next time :-). Keep the spoon ready.
Thanks a lot to you both. Been using this thread to completely reverse buttons & positions in Home Assistant, for Tuya curtain modules that work fine, but display reversed status & position values in hass.io
I included all this in a “covers.yaml” file, and added just the include at the end of configuration.yaml:
cover: !include covers.yaml
Hey everyone
When I try this, I get an error that “position is undefined”
I get that same error in the template editor if I paste in your version too.
My version:
bedroom_large_left:
friendly_name: "Bedroom Blinds Large Left"
position_template: "{{ 100 - state_attr('cover.bedroom_blinds_c_left', 'current_position') | int(100) }}"
value_template: "{{ (100 - state_attr('cover.bedroom_blinds_c_left', 'current_position') | int(100)) > 95 }}"
open_cover:
service: cover.close_cover
data: {}
entity_id: cover.bedroom_blinds_c_left
close_cover:
service: cover.open_cover
data: {}
set_cover_position:
service: cover.set_cover_position
position: "{{100-position}}"
icon_template: >-
{% if is_state('cover.bedroom_blinds_c_left', 'closed') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
You shouldn’t get that error in your configuration. You’ll get that error in the template editor area because position doesn’t exist in the template editor.
Your comment made YouTube. FINALLY! A CHEAP Zigbee SOLAR POWERED Smart Blind Motor - YouTube skip to 6:30
Yep, I know.
My “created” template code from above does not actually always work. E.g. when I have the cover half open and restart HA, It lost it’s state and I need to fully open or close it to reflect the actual state.
I admit: I am not a coder (templates). However I am a very enthusiastic HA user that like things working, even if that means I need to ask for help here.
Although I think, given the amount of questions and topics on templates, and especially this one, it is not easy at all.
What’s the attribute current_position
value at startup on cover.bedroom_blinds_c_left
I have been playing with this for hours and I can’t make it work. My version does reverse the blind but I can’t restart HA, I always get the error:
The system cannot restart because the configuration is not valid: Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/covers.yaml”, line 2, column 11
Here is mine (content of covers.yaml), it’s just a paste of the above but with my blind:
covers:
dining_room_blind_reversed:
friendly_name: "Dining room blind reversed"
position_template: "{{ 100 - state_attr('cover.dining_room_blind_cover', 'current_position') | int(100) }}"
open_cover:
data: {}
entity_id: cover.dining_room_blind_cover
close_cover:
data: {}
stop_cover:
service: cover.stop_cover
data: {}
set_cover_position:
icon_template: >-
{% if is_state('cover.dining_room_blind_cover', 'closed') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
I’m happy to have a bash at stuff but this is all new to me, I’m not a coder
covers:
Thank you. I can’t believe it’s that simple!
Thanks for the solution which is quite perfect in my case to swap the buttons.
However, it has a problem: it is based on the position_template
I’m attaching a view of the normal and inverted (reversed) cover:
The reversed buttons and the icons are perfect with your solution, but I would like to invert also the slider percentage. I don’t think this is possible, right?
Just want to say that the solution provided worked perfectly for my tuya zigbee blinds, thanks! I got the blind motor installed and HA seeing the device with minimal effort, the only issue was HA showing the inverted state of the blinds and nothing I did could change it.
I think it helped that I didnt want the slider, just up and down.
How would I create the “opening” and “closing” status on this cover, independent of the original cover?
you can make a template binary sensor w/ device_class: door
or opening
Sorry, I didn’t express myself well. If the question is simple, sorry,
I’m new to this, I’ll rephrase the question. I need the “opening” and “closing” statuses of the cover, but they are inverted. My code worked until a specific condition, resulting in the table below.
when the cover is fully closed and is operated to open. it physically opens, but the status remains “closed”. To adjust this I thought about creating the “opening” and “closing” status for “cover1 reversed” differently from the way I did it in my code. But I was unsuccessful.
Correct
set action | cover1 (action) | cover1 (status) | cover1 reversed (action) | cover1 reversed (status) |
set open | close | closing | open | opening |
set close | open | opening | close | closing |
current position | cover1 (status) | cover1 reversed (status) |
0 | closed | closed |
>0 | open | open |
current position | set_action | physical motion | cover1 (status) | cover1 reversed (status) |
0 (closed) | set open | opening | closed | closed |
100 (open) | set_close | closing | open | open |
covers:
cover1_reversed:
friendly_name: "Cover1 Reversed"
position_template: "{{state_attr('cover.cover1', 'current_position') | int(100) }}"
open_cover:
data: {}
entity_id: cover.cover1
close_cover:
data: {}
stop_cover:
data: {}
set_cover_position:
position: "{{position}}"
value_template: >-
{% if state_attr('cover.cover1', 'current_position') == 0 %}
closed
{% elif state_attr('cover.cover1', 'current_position') == 100 %}
open
{% elif is_state('cover.cover1', 'closed') %}
closed
{% elif is_state('cover.cover1', 'closing') %}
opening
{% elif is_state('cover.cover1', 'opening') %}
closing
{% else %}
open
{% endif %}
icon_template: >-
mdi:roller-shade-closed
mdi:blinds-open
mdi:arow-up-box
mdi:arow-down-box
{% else %}
mdi:blinds-open
{% endif %}
I was just doing something similar. The code below works for me with the caveat that for my use-case the active/inactive status would ideally not be reversed. I really wish that all of the logic for covers was in the back end rather than some of it living the front end.
cover:
covers:
cover_screen_reversed:
friendly_name: "Screen Reversed"
position_template: "{{ 100 - state_attr('cover.screen', 'current_position') | int(100) }}"
value_template: >-
{% if is_state('cover.screen', 'closing') %}
opening
{% elif is_state('cover.screen', 'opening') %}
closing
{% else %}
none
{% endif %}
open_cover:
data: {}
entity_id: cover.screen
close_cover:
data: {}
stop_cover:
data: {}
set_cover_position:
icon_template: >-
{% if is_state('cover.screen', 'closed') %}
mdi:projector-screen-variant-off-outline
{% elif is_state('cover.screen', 'closing') %}
mdi:arrow-up-box
mdi:arrow-down-box
{% else %}
mdi:projector-screen-variant-outline
{% endif %}
Hope that it makes sense to post this here - the forum is warning me that this thread is now closed but your post looks relatively recent.
Hello, sorry I´m new into this but I have been able to add the code and it started to work. But I have a problem. The code created me 2 devices in the control panel.
The issues is that as soon as I activate the first one (with your code) it start fine but 2 seconds later start the old device starts and change the direction.
Can you help me to undertand what I´m doing wrong?
thanks for ther solution… I have the same problem in tuya cloud connected shutters (on tuya app the buttons are fine)…Im worried that if I do coding for the buttons that tuya at some point fix it and now it will be a problem as Im doing automation to close the shutters automatically at midnight …now it will be opened wide open for any one at mid night…any permanent fix with tuya or something like that? why on the first place something like that happens?
