This morning 2 of my roller shutters did not operate as expected. With both roller blinds, the window was opened for ventilation before the planned opening and then closed again. The roller blinds (OG_F1) then lowered again, but did not raise again when they were opened as planned. This will now only take place at the latest opening time.
Shuttercontrol - Bad_EG_F1
alias: Shuttercontrol - Bad_EG_F1
description: ""
use_blueprint:
path: hvorragend/cover_control_automation.yaml
input:
blind: cover.bad_eg_f1_rollo
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_sun_enabled
- auto_brightness_enabled
time_up_early: "05:00:00"
time_up_early_non_workday: "07:30:00"
time_up_late: "07:30:00"
default_brightness_sensor: sensor.ms_garagentur_illuminance
brightness_up: 45
brightness_down: 42
workday_sensor: binary_sensor.workday_sensor
shading_azimuth_start: 0
shading_azimuth_end: 53
shading_temperatur_sensor1: sensor.weatherman_sonnen_temperatur
shading_min_temperatur1: 35
shading_tilt_position: 50
shading_cover_position: 20
shading_waitingtime_start: 60
shading_waitingtime_end: 300
position_tolerance: 1
open_position: 100
cover_status_options: cover_helper_enabled
cover_status_helper: input_text.shutter_status_bad_eg_f1
Shutter_Status_Bad_EG_F1
{"open":{"a":false,"t":1709527337},"close":{"a":false,"t":1709529322},"ventilate":{"a":false,"t":0},"shading":{"a":false,"t":0},"locked":{"a":false,"t":0},"manual":{"a":true,"t":1709531358},"v":3,"t":1709531358}
Shuttercontrol - OG_2_F1
alias: Shuttercontrol - OG_2_F1
description: ""
use_blueprint:
input:
auto_up_options: auto_up_enabled
time_up_early_non_workday: "08:00:00"
time_down_late: "20:00:00"
brightness_down: 42
brightness_up: 45
auto_sun_options: auto_sun_disabled
ventilate_position: 99
shading_azimuth_start: 143
shading_azimuth_end: 233
shading_min_temperatur1: 33
blind: cover.og_2_f1_rollo
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_shading_enabled
- auto_ventilate_enabled
sun_elevation_up: 0
sun_elevation_down: 0
open_position: 100
cover_status_helper: input_text.shutter_status_og_2_f1
contact_sensor: binary_sensor.og_2_f1_kontakt
ventilate_tilt_position: 20
shading_tilt_position: 25
close_tilt_position: 20
Shutter_Status_OG_1_F1
{"open":{"a":false,"t":1709528247},"close":{"a":false,"t":1709485738},"ventilate":{"a":false,"t":1709486528},"shading":{"a":false,"t":0},"locked":{"a":false,"t":0},"manual":{"a":true,"t":1709529986},"v":3,"t":1709529986}
[trace automation.shuttercontrol_0g_2_f1_hvorragend 2024-03-04T05_48_03.652404+00_00.json - Google Drive]
[trace automation.shuttercontrol_0g_2_f1_hvorragend 2024-03-04T05_47_25.876364+00_00.json - Google Drive]
Unfortunately no start-up after the latest time
https://drive.google.com/file/d/1rNatUySem9wBKB2K5d_17LTYFTutFqwx/view?usp=share_link
https://drive.google.com/file/d/15BKpSNBbFr2uZmOf0DGxz29iAS3_70bx/view?usp=share_link
