Hello everyone, I would like to introduce you to my roller shutter blueprint:
Cover Control Automation (CCA)
My GitHub Project |
Full Changelog on Github
Current version: 2025.08.15
If you would like to support me or say thank you, please click here:
PayPal Donation |
Buy me a coffee
FEATURES
- Opening and Closing: Automatically opens and closes roller shutters based on brightness, sun elevation, and within specified time windows.
- Ventilation Feature: Supports two-way sensors for ventilation, allowing for partial opening to ventilate the room.
- Resident Feature: Keeps the cover closed if a resident is detected as asleep, ensuring comfort and privacy.
- Drive Delay: Offers both fixed and random delays for driving the covers, providing flexibility in operation.
- Trigger Waiting Time: Configurable waiting time for triggers to avoid rapid, unnecessary movements.
- Position Tolerance: Adjustable tolerance for cover positions to account for minor discrepancies in cover movement.
- Dynamic Conditions: Features can be activated or deactivated based on dynamic conditions such as:
- Vacation Mode: Keeps covers closed during vacations.
- Party Mode: Prevents covers from closing during parties.
- Shading Boolean: Controls shading activation and deactivation.
- Maintenance Mode: Suspends cover control during maintenance or cleaning.
- Manual Override Detection: Detects manual overrides and adjusts automation to prevent conflicts.
- Time-Based Control: Configures cover control based on workdays and non-workdays, allowing different schedules.
- Sun Elevation-Based Control: Adjusts cover positions based on the sun’s elevation to optimize natural light and heat.
- Brightness-Based Control: Uses ambient brightness levels to manage cover positions, enhancing energy efficiency.
- Position Management: Manages multiple positions for different states such as open, close, ventilate, and shading. Added the option to save the current status in a helper. This has the advantage that the roller blind can also be in other positions and the automation can still be executed. And manual interventions are not constantly overridden with every trigger.
- Sun Shading / Sun Protection: Extensive automatic sun shading with many different setting options: Sun azimuth, Sun elevation, Solar irradiation/Light intensity/Illuminance, Weather Conditions, Temperature sensors (compare thresholds for indoor and/or outdoor sensors), weather forecast comparison
FAQ
General Questions
- What are the minimum requirements for using the CCA Blueprint?
- The cover/shutter must have a
current_positionattribute. - Shutters need to be properly integrated into Home Assistant.
- The
sun.sunentity must be enabled and working correctly. - Minimum required version of Home Assistant: 2024.6.0
Configuration Questions
How do I set up the basic position settings?
- Set
open_position(typically 100). - Set
close_position(typically 0). - Configure
drive_time(default 90 seconds).
- Set
What are the important configuration rules?
- Ensure time settings follow logical order (early times before late times).
- Position values should be hierarchical:
open_position > ventilate_position > close_position.
Feature Questions
How does the ventilation feature work?
- Supports two-way sensors for partial opening to ventilate the room.
- Or use the sensors for lock-out protection
What is the resident feature?
- Keeps the cover closed if a resident is detected as asleep.
How can I detect manual overrides?
- The blueprint includes a feature to detect manual overrides and adjust automation accordingly.
How do the shading start conditions work?
- If multiple criteria (e.g. temperature sensors and/or azimuth and/or elevation) are defined, shading will not occur until all criteria are met.
How can I use additional conditions like vacation mode or party mode?
- Activate vacation mode to keep covers closed during vacations.
- Use party mode to prevent covers from closing during parties.
Advanced Questions
Can I configure the blueprint based on sun elevation and brightness?
- Yes, the blueprint allows adjustments based on sun elevation and ambient brightness levels.
How do I manage multiple positions for different states?
- The blueprint supports managing positions for open, close, ventilate, and shading.
SCREENSHOTS
CHANGELOG
Some recent changes
2025.05.27
- Updated: Revised information text for configuring the position configuration
- Added: The schedule helper state has been added as a variable. This is just for debugging purposes. #214
- Fixed: The problems with the start of shading have been corrected. #212 #211
If the shading conditions were not still fulfilled after the end of the waiting time, the sun protection was sometimes not activated correctly.
Now we have a new feature and we can select the following options:- If the conditions were not permanently fulfilled, we can wait for another trigger to be executed. The previous pending status is now successfully reset.
- And much better: CCA can be configured so that we can periodically check the shading during the day. The system then checks again and again until the conditions are valid again.
2025.05.20
- Fixed: Wrong default value for shading_forecast_temp
2025.05.14
- Added: Falling below shading_elevation_max now also triggers Shading Start #193
- Fixed: When detecting manual position changes, values greater than Ventilation were incorrectly assumed to be Open. This was too wide-ranging.
2025.05.13
- Fixed: The nightly shading reset has changed the timestamp and therefore a new shading with active ‘prevent_shading_multiple_times’ can never be executed.
2025.05.12:
- Fixed: Multiple triggering of a detected shading has skipped the waiting time until execution #206
2025.05.11:
- Fixed: Fixed bug that the cover can be opened again by the time-up-late-trigger despite existing shading.
2025.05.07:
- Fixed: Shading is now also recognized and temporarily stored in the helper if the resident sensor contains the value true. #131
- Added: Tilt Reposition Feature (Thanks for the pull request, Astado) #196
- Update: Better textual clarification of what the result of the additional condition should look like #204
- Update: Only shade the cover when it is not in the shading position. Purely as a precautionary measure in case the target state and actual state do not match.
2025.05.04:
- Added: Allow immediate ending of shading if the sun is out of the defined azimuth or elevation range #202 (thank you, jpawlowski)
- Added: Option to close cover instead of opening when shading ends (ideal for awnings) #203 (thank you, jpawlowski)
- Updated: Note that the weather sensor specification is optional #198
2025.05.02-02:
- Fixed: A bug has been fixed that caused the shading to be recognized but not executed. But only if shading was only allowed to be executed once a day.
2025.05.02-01:
- Fixed: Also take into account for shading that a door contact only needs to be tested when ventilation mode is switched on #197
- Fixed: Removed protocol error that occurs during manual execution.
- Added: Catching an incorrect weather configuration
- Added: Ability to specify an existing sensor if it already provides daily maximum temperature forecast instead of weather entity #199
- Added: Add hysteresis for temperature sensor based shading #189
2025.04.18:
- Updated: Just to be more bulletproof, the tilt position control can now be specifically switched on or off. Please activate if necessary. #163
- Updated: There is no default value for “Sun Shading Forecast Temperature” here now. To not compare the forecast temperature, leave this field empty. #179
- Added: Allow entities of the switch domain as resident sensor or with the force entities #167
- Added: New additional actions: Commands can now be executed before opening, closing, shading and ventilation #166
- Fixed: Fixed problems resetting manual override #184
- Fixed: Make sure that the reset of the manual override is only executed once #178
- Fixed: Problems with lockout protection and partial ventilation solved #181
- Fixed: There was no latest time for closing the cover when the scheduler was used with sun/brightness #170
- Added: Added Sun elevation examples into the description #175
- Added: New feature ‘Allow opening the cover when resident is still present’ #192
- Breaking change: Please reconfigure “Allow sun protection when resident is still present” (‘resident_shading_enabled’ was renamed)
2025.06.07
- Added: Resident check for ventilation #216 (Thanks for the pull request, Astado)
- Added: Better description for shading_forecast_sensor (Thanks you, Eimeel)
- Fixed: Solve Issue with sun shading end if Tilt Position Control is enabled #216 (Thanks for the pull request, Astado)
- Fixed: Shades are being opened or closed even if they are already #219
- Fixed:
When the “End Sun Shading Immediately When Out Of Range” mode was activated, the shading of the cover was not canceled.
This was because the new waiting time was set to 0 seconds and CCA could not trigger itself in the same second via a helper. - Updated: Extensive code refactoring
- Updated:
Automation mode changed to ‘single’ as a test, because otherwise new triggers in the delay would interfere with processing.
In the worst case, I will have to work with {{ state_attr(‘automation.cca_automation’, ‘current’) > 0 }} as before to be able
to intercept the reciprocal triggers.
2025.06.10
- Fixed: The detection of weekdays and weekends is working again.
2025.06.11
- Fixed: Error fixed if the Workday Tomorrow sensor was not specified
2025.06.12
- Fixed: Increased the delay to 20 seconds for the “End Sun Shading Immediately When Out Of Range” feature. This change aims to ensure the new trigger executes reliably, as Home Assistant appears to ignore shorter delay values.
- Updated: Refactored helper_state_json to include a more robust fallback mechanism.
- Improved: Shading end triggers have been restructured to activate only when shading is currently active.
- Refactored: Codebase has been restructured to use YAML anchors, improving maintainability and reducing redundancy.
2025.06.13-02
- Fixed incorrect use of is_state() with potentially invalid inputs
- Improved robustness using states() with type checks
- Handled optional workday sensor inputs gracefully
2025.06.19:
- Fixed: Tilt Delay added again
- Fixed: Even though no shading was explicitly applied, the shading has ended for a closed cover #226
- Added: Add sun shading minimum tilt position (Thank you for the pull request, julianwachholz) #230
2025.07.10:
- Fixed an issue where shading could not be activated while tilt mode was active
- Fixed a bug where shading would start unexpectedly even though the sun was on the opposite side of the building (#244)
- Fixed a failure in the lockout protection mechanism (#225)
- Fixed an issue where forced tilt reset was not skipped when changing tilt positions (#241)
- Fixed a bug where shading end conditions were not properly checked (#229)
- Added: Option to additionally allow temperature+forecast-only shading (#238)
- Added: Configuration option to compare forecast temperature with Sensor 2 (#238)
- Memo: Slight adjustment to the calculation of is_helper_shaded: pending shading end is no longer considered.
2025.07.30:
- Fixed: Shading not ending when condition changed in previous waiting time #258
- Fixed: Shading not ending because of general conditions #257
- Fix only tilt open is not ending shading #255
2025.08.07:
- Fixed a bug where shading was not disabled when the weather sensor or optional weather conditions were not set #258
2025.08.10:
- Minor updates
2025.08.15:
- Fixed: In rare cases, global conditions prevented the helper from being pre-filled #270
I hope you have lots of fun with this version. ![]()
And please don’t forget the little heart here. Thank you.
