Cover Control Automation (CCA) - Intelligent Automation for Blinds, Awnings & Shutters | Calendar, Sun Shading, Force Functions
Could it be, that you forgot to define your sun sensor?
If you just want to use the azimuth/elevation of the sun, its not neccessary to enable the time based options for open and close! so try to disable them!
Hi, tanx for your answer!
I use the HA-includet sun-sensor (sun.sun) and i use a calender entity. That works without problems.
Or is there an another sun sensor i have to use?
no the included sun sensor should do the work :slight_smile:
Hi, I just noticed that there are a few similar issues on GitHub (#395, #398, #408…)
If my traces and/or helper stats would be helpful for further analysis, please let me know.
For now, I’m waiting for the announced fix…:raising_hand_man:t3:
Since my English isn’t the best, unfortunately, and I have to read a lot of things twice to understand them, would it be easier for me if the whole thing were also available in German? Is it possible to translate the whole thing? Like a German version?
Also many thanks from my end. Very impressive!
I’ve automated some of the normal blinds and would like to extend my configurastion to velux roof windows with electrical motor and electrical blinds.
Here, it would be perfect to consider both, windows position and blind position (Blinds can’t be closed if window is fully open)
I’ve seen the bianry inputs to detect open / ventilating windows.But what I don’t understand: Is there any option to control the window position out of CCA?
There is one more constraint as the control unit (of the window) only allows to control window or blinds at the same time.
Consequently, a sequence might look like
  • Sun Shading request detected ( e.g. based on #187)
  • Move window to closed position
  • wait until it is reached ( 1 Minute)
    *Move blinds o shading position
Any experiences with such a setup?
The summer has arrived and my shading is not working anymore. Somehow east windows are working but south and west is not triggered. Trace analyzer shows temperature as and condition but they are configured as or.
This is the trace
And here is the config
alias: Rollo außen auto
description: ""
use_blueprint:
  path: hvorragend/cover_control_automation.yaml
  input:
    blind: cover.rolladen_ausen
    auto_options:
      - auto_up_enabled
      - auto_down_enabled
      - auto_shading_enabled
      - auto_ventilate_enabled
      - auto_sun_enabled
    ignore_after_manual_config: []
    reset_override_config: reset_disabled
    reset_override_time: "00:10:00"
    cover_status_options: cover_helper_enabled
    cover_status_helper: input_text.rolladen_aussen_helfer
    drive_time: 25
    ventilate_position: 20
    shading_position: 25
    time_up_early: "06:35:00"
    time_up_early_non_workday: "08:00:00"
    time_up_late_non_workday: "09:00:00"
    sun_elevation_down: -3
    sun_elevation_up: 9.8
    contact_sensor: binary_sensor.kontakt_ausen
    shading_azimuth_start: 120
    shading_forecast_sensor: weather.ruesselsheim
    shading_weather_conditions:
      - sunny
      - partlycloudy
      - cloudy
      - clear
      - rainy
      - exceptional
    position_tolerance: 0
    check_config: false
    shading_forecast_type: weather_attributes
    shading_min_temperatur1: 19
    workday_sensor: binary_sensor.workday_sensor
    shading_min_temperatur2: 19
    shading_temperatur_sensor1: sensor.dwd_max_temp
    contact_window_tilted: binary_sensor.kontakt_ausen
    shading_conditions_start_and:
      - cond_azimuth
      - cond_elevation
      - cond_forecast_weather
    shading_conditions_start_or:
      - cond_temp1
      - cond_temp2
    shading_conditions_end_or:
      - cond_azimuth
      - cond_elevation
    shading_temperatur_sensor2: sensor.haydnstrasse_temperatur
Can someone help me please?
i got also a problem with the actual version and the sun shading part. None of covers go to sun shading position after the automations where triggered! All shading automations worked fine last year, and i didn’t change things in it, only the new versions of this blueprint! The CCA-Validator said, that all is fine! The trace analyser said that there are some values out of the range, but thats not true! The trace i uploaded here. Hopefully someone can help!
now i hang on the same bugs…
I don’t have a solution for your problem but I hit the same problem in the sense it worked fine last year but now no cover are going to shading position. I think this blue print got way to complicated and I just gave up on it. Instead, a few days ago I had GitHub Copilot look at my 6 configured cover automations and create much simpler versions on just the actually few features I used for each cover. And these just work for me now.
Glad to see that I’m not the only one. Looking back and forth to what I did wrong as no changes were applied to the settings, just keep updating and it also is not working. Looking forward to the ā€œto be releasedā€ version being worked on to hopefully gain back shading before it really starts getting hot out there. :hot_face: :sweat_smile:
actually i use the dev-version and yesterday it worked as it should :slight_smile:
That’s good to hear.
I’ve made quite a few changes over the last few days. But I haven’t tested them thoroughly yet. Once that’s done, there will be a release.
I think it is a problem with the migration through different versions. I created a new one from scratch and now it’s working for this cover.
after adding all conditions it stopped working again. I figured now out that the weather condition is the issue. If I remove the weather condition the shading is working.
I am using a standard dwd weather entity. Any idea?
the question is, what do you use from the weather entity?
Which version of the blueprint?
which configuration is working and which is not working?
Hi Mr.Herr.Vorragned,
I am testing the 2026.05.05 beta, because I do have also issues with the blueprint always shading.
I have added a github issue topic including all the logs and further details.
Maybe you can keep an eye on it. Also tried to start the blueprints from scratch with new settings, but did not work.
Where can I find the log book entries?
Regards!
Thanks für feedback. Version 2026.05.10 V2 Beta seems to work now much better!
I had a very old version of this blueprint running (2024.8). I updated Yesterday to version 2026.1.26. My homematic driven blinds were not working anymore with blueprint and decided to setup new automations.
What i have noticed:
Blinds work when action before close is setup. But the helper gets the position only when action after close is setup. Do i have to adf the homematic service to both or is there something i am missing?
Furthermore, can i use control of cover and tilt without additional action for homematic?
Seems like i have to create new helpers. I will follow up after holidays.
