Thank you for the detailed explanation.
I’m still struggling with some details.
From my understanding, the ignore_ventilation_after_manual option prevents the cover from moving to the ventilation position after it has been moved manually. However, in my case, the ventilation condition was not the trigger. Instead, closing the door caused the cover to move to the fully closed position.
This morning i opened the cover manually (08:24:46). After that I opened the door (08:25:16). When I closed the door (08:37:47), the cover went down(08:37:53).
Here is the activity log from the helper:
entity_id,state,last_changed
input_text.hlp_ez_rollladen,"{""bas"":""cls"",""shd"":0,""pnd"":""non"",""win"":""cls"",""frc"":""non"",""res"":0,""man"":0,""ts"":{""opn"":0,""cls"":0,""shd"":1785085866,""due"":0,""arm"":0,""man"":1785474247},""v"":6,""t"":1785736458,""d"":1785702603}",2026-08-03T06:00:00.000Z
input_text.hlp_ez_rollladen,"{""bas"":""cls"",""shd"":0,""pnd"":""non"",""win"":""opn"",""frc"":""non"",""res"":0,""man"":0,""ts"":{""opn"":0,""cls"":0,""shd"":1785085866,""due"":0,""arm"":0,""man"":1785474247},""v"":6,""t"":1785738322,""d"":1785702603}",2026-08-03T06:25:21.762Z
input_text.hlp_ez_rollladen,"{""bas"":""cls"",""shd"":0,""pnd"":""non"",""win"":""cls"",""frc"":""non"",""res"":0,""man"":0,""ts"":{""opn"":0,""cls"":0,""shd"":1785085866,""due"":0,""arm"":0,""man"":1785474247},""v"":6,""t"":1785739075,""d"":1785739075}",2026-08-03T06:37:55.038Z
input_text.hlp_ez_rollladen,"{""bas"":""cls"",""shd"":0,""pnd"":""non"",""win"":""cls"",""frc"":""non"",""res"":0,""man"":0,""ts"":{""opn"":0,""cls"":0,""shd"":1785085866,""due"":0,""arm"":0,""man"":1785474247},""v"":6,""t"":1785739542,""d"":1785739075}",2026-08-03T06:45:42.342Z
input_text.hlp_ez_rollladen,"{""bas"":""cls"",""shd"":0,""pnd"":""beg"",""win"":""cls"",""frc"":""non"",""res"":0,""man"":0,""ts"":{""opn"":0,""cls"":0,""shd"":1785085866,""due"":1785742201,""arm"":1785742200,""man"":1785474247},""v"":6,""t"":1785739866,""d"":1785739075}",2026-08-03T06:51:05.698Z
Here is the trace:
this:
entity_id: automation.ez_rollladen
state: 'on'
attributes:
last_triggered: '2026-08-03T06:25:45.254637+00:00'
mode: queued
current: 0
max: 25
icon: mdi:blinds-horizontal
friendly_name: EZ Rollladen
last_changed: '2026-08-03T05:54:16.695412+00:00'
last_reported: '2026-08-03T06:25:45.371104+00:00'
last_updated: '2026-08-03T06:25:45.371104+00:00'
context:
parent_id: 01KZ34QM5B0V7TPJB5H3XQPDP5
user_id: null
idx: '16'
alias: null
platform: state
entity_id: binary_sensor.ez_fensterkontakt_contact
from_state:
state: 'on'
attributes:
device_class: door
friendly_name: EZ Fensterkontakt Tür
last_changed: '2026-08-03T06:25:16.073343+00:00'
last_reported: '2026-08-03T06:25:16.073343+00:00'
last_updated: '2026-08-03T06:25:16.073343+00:00'
context:
parent_id: null
user_id: null
to_state:
state: 'off'
attributes:
device_class: door
last_changed: '2026-08-03T06:37:47.745433+00:00'
last_reported: '2026-08-03T06:37:47.745433+00:00'
last_updated: '2026-08-03T06:37:47.745433+00:00'
context:
parent_id: null
user_id: null
for:
__type: <class 'datetime.timedelta'>
total_seconds: 2
attribute: null
description: state of binary_sensor.ez_fensterkontakt_contact
blind: cover.ez_rollladen
cover_type: blind
is_awning: false
resident_sensor: []
resident_config: []
position_source: current_position_attr
custom_position_sensor: []
open_position: 100
close_position: 0
ventilate_position: 30
lockout_position: []
shading_position: 20
shading_position_alt: []
shading_position_alt_entity: []
position_tolerance: 3
open_tilt_position: 100
close_tilt_position: 0
ventilate_tilt_position: 50
tilt_position_tolerance: 0
shading_tilt_elevation_1: 20
shading_tilt_elevation_2: 30
shading_tilt_elevation_3: 48
shading_tilt_position_0: 0
shading_tilt_position_1: 20
shading_tilt_position_2: 37
shading_tilt_position_3: 50
auto_options:
- auto_up_enabled
- auto_down_enabled
- auto_sun_enabled
- auto_lockout_protection_enabled
- auto_shading_enabled
- auto_ventilate_enabled
- time_control_enabled
cover_tilt_config: cover_tilt_disabled
cover_tilt_reposition_config: cover_tilt_reposition_disabled
is_cover_tilt_enabled: false
tilt_wait_mode: fixed_delay
tilt_wait_timeout: 30
is_tilt_wait_idle_mode: false
is_tilt_before_position_mode: false
time_up_early: '06:45:00'
time_up_early_non_workday: '09:30:00'
time_up_late: '09:00:00'
time_up_late_non_workday: '09:30:00'
time_down_early: '16:00:00'
time_down_early_non_workday: '16:00:00'
time_down_late: '22:30:00'
time_down_late_non_workday: '22:30:00'
workday_sensor_today: binary_sensor.workday
workday_sensor_tomorrow: []
time_control: time_control_input
calendar_entity: []
calendar_open_title: Open Cover
calendar_close_title: Close Cover
calendar_open_title_lc: open cover
calendar_close_title_lc: close cover
is_calendar_enabled: false
default_brightness_sensor: []
brightness_up: 0
brightness_down: 0
brightness_hysteresis: 0
brightness_sun_operator: or
default_sun_sensor: sun.sun
sun_elevation_mode: fixed
sun_elevation_up: 0
sun_elevation_down: -4
sun_elevation_up_sensor: []
sun_elevation_down_sensor: []
contact_window_opened: binary_sensor.ez_fensterkontakt_contact
contact_window_tilted: []
lockout_tilted_options:
- lockout_tilted_shading_start
- lockout_tilted_shading_end
- lockout_tilted_closing
shading_azimuth_start: 78
shading_azimuth_end: 230
shading_elevation_min: 20
shading_elevation_max: 90
shading_sun_brightness_start: 35000
shading_sun_brightness_end: 25000
shading_sun_brightness_hysteresis: 0
shading_brightness_sensor: []
shading_temperatur_sensor1: sensor.eg_temperature
shading_temperatur_sensor2: sensor.drausen_temperature
shading_min_temperatur1: 23
shading_min_temperatur2: 23
shading_temperature_hysteresis1: 0.2
shading_temperature_hysteresis2: 1
shading_forecast_sensor: []
shading_forecast_temp_sensor: []
shading_forecast_type_raw: hourly
shading_forecast_type: hourly
shading_forecast_temp: 23
shading_forecast_temp_hysteresis: 0
shading_independent_temp: 25
shading_weather_conditions:
- sunny
- partlycloudy
- clear
- windy
shading_custom_sensor: []
shading_conditions_start_and:
- cond_azimuth
- cond_elevation
- cond_temp1
- cond_temp2
shading_conditions_start_or: []
shading_conditions_end_and: []
shading_conditions_end_or:
- cond_azimuth
- cond_elevation
- cond_temp1
- cond_temp2
lockout_tilted_when_closing: true
lockout_tilted_when_shading_starts: true
lockout_tilted_when_shading_ends: true
is_shading_enabled: true
is_up_enabled: true
is_down_enabled: true
is_brightness_enabled: false
is_sun_elevation_enabled: true
use_and_operator: false
is_time_field_enabled: true
is_time_control_disabled: false
is_opening_scheduled: true
is_ventilation_enabled: true
recovery_config: never
recovery_mode: never
is_recovery_enabled: false
reset_override_config:
- reset_fixed_time
reset_override_time: '11:00:00'
reset_override_timeout: 120
reset_override_position: 100
reset_override_position_dwell: 5
is_reset_fixed_time: true
is_reset_timeout: false
is_reset_position: false
is_reset_disabled: false
auto_up_force: []
auto_down_force: input_boolean.xmas_force_close_cover
auto_ventilate_force: []
auto_shading_start_force: []
force_pause: []
cover_status_helper: input_text.hlp_ez_rollladen
instance_active: []
instance_active_value: ''
invalid_states:
- unavailable
- unknown
- none
- None
- 'null'
- query failed
critical_entities:
- cover.ez_rollladen
automation_entity: automation.ez_rollladen
version: 2026.07.25 V2
is_paused: false
blind_entities:
current_position: 100
current_tilt_position: 101
effective_shading_position: 20
effective_lockout_position: 100
position_comparisons:
current_above_open: false
current_above_close: true
current_above_shading: true
current_above_ventilate: true
current_below_open: false
current_below_close: false
current_below_shading: false
current_below_ventilate: false
open_above_close: true
open_above_ventilate: true
shading_above_close: true
shading_below_open: true
ventilate_above_close: true
shading_below_ventilate: true
current_sun_azimuth: 89.48
current_sun_elevation: 22.43
sun_elevation_up_current: 0
sun_elevation_down_current: -4
is_today_off: true
is_tomorrow_off: false
is_tomorrow_on: false
is_cover_tilt_enabled_and_possible: false
is_cover_tilt_reposition_enabled: false
drive_delay_fix: 0
drive_delay_random: 5
drive_time: 90
time_up_early_today: '09:30:00'
time_up_late_today: '09:30:00'
time_down_early_today: '16:00:00'
time_down_late_today: '22:30:00'
shading_tilt_position: 20
in_open_position: true
in_lockout_position: true
in_close_position: false
in_shading_position: false
in_ventilate_position: false
in_reset_override_position: false
brightness_time_duration: 30
sun_time_duration: 30
shading_waitingtime_start: 300
shading_waitingtime_end: 300
shading_start_max_duration: 7200
shading_end_max_duration: 7200
shading_config: []
shading_end_immediate_by_sun_position: false
is_shading_end_immediate_by_sun_position: false
forecast_source:
use_sensor: false
use_weather: false
prevent_service: false
shading_start_condition_enabled:
azimuth: true
elevation: true
brightness: false
temp1: true
temp2: true
forecast_temp: false
forecast_weather: false
custom: false
shading_end_condition_enabled:
azimuth: true
elevation: true
brightness: false
temp1: true
temp2: true
custom: false
helper_json:
bas: cls
shd: 0
pnd: non
win: opn
frc: non
res: 0
man: 0
ts:
opn: 0
cls: 0
shd: 1785085866
due: 0
arm: 0
man: 1785474247
v: 6
t: 1785738322
d: 1785702603
state_resident: false
resident_flags:
opening_trigger: false
closing_trigger: false
allow_open: true
allow_shade: true
allow_ventilate: true
effective_state: cls
helper_state_force: non
helper_state_resident: false
helper_state_manual: false
helper_state_base: cls
helper_state_window: opn
helper_state_shade: false
helper_ts_open: 0
helper_ts_close: 0
helper_ts_shade: 1785085866
helper_ts_pending_arm: 0
helper_ts_man: 1785474247
helper_ts_pending_due: 0
configured_entities:
- input_text.hlp_ez_rollladen
- binary_sensor.ez_fensterkontakt_contact
- sun.sun
- sensor.eg_temperature
- sensor.drausen_temperature
- binary_sensor.workday
- input_boolean.xmas_force_close_cover
helper_ts_write: 1785738322
helper_ts_drive: 1785702603
automation_resumed: false
instance_active_on_states:
- 'on'
- 'true'
instance_activated: false
is_restart_run: false
recovery_catch_up: false
stale_day: false
override_expired: false
helper_state_is_shaded: false
helper_state_pending: non
helper_state_pending_start: false
helper_state_pending_end: false
midnight_reset_missed: false
is_forced_open: false
is_forced_close: false
is_forced_shade: false
is_forced_vent: false
is_forced: false
force_helper_unreadable: false
live_force: non
force_allows_open: true
force_allows_close: true
force_allows_shade: true
force_allows_ventilate: true
ignore_after_manual_config:
- ignore_opening_after_manual
- ignore_closing_after_manual
override_flags:
opening: true
closing: true
ventilation: false
shading: false
override_blocks:
opening: false
closing: false
ventilation: false
shading: false
auto_ventilate_options: []
contact_delay_trigger: 2
contact_delay_status: 3
ventilation_flags:
start_no_delay: false
delay_enabled: false
if_lower_enabled: false
after_shading_end: false
keep_open_on_full_to_tilt: false
prevent_config:
- prevent_shading_multiple_times
prevent_flags:
higher_position_closing: false
lowering_when_closing_if_shaded: false
shading_end_if_closed: false
opening_after_shading_end: false
opening_after_ventilation_end: false
default_cover_actions: false
shading_multiple_times: true
opening_multiple_times: false
closing_multiple_times: false
auto_recover_after_force: auto_recover_disabled
is_force_recovery_enabled: false
check_config: false
check_config_debuglevel: info
check_status_helper_length: 254
enable_logbook: false
Thanks a lot!
