Cover entities that are 0% = open and 100% = closed
If you are not happy with HA’s cover interpretation of 0 = closed and 100 = open then you are not alone.
In 2020 I sparked a WTH discussion about that topic. It triggered a heated debate:
That discussion also offered multiple workarounds based either on Template Cover entities or on entities created in Node RED flows. There are also a hand full of related questions about that in the forum that provide answers of different maturity level.
Today I want to collect all the bits and pieces and start a guide that boils it all down. Guides in this forum can be edited by other users. So be my guest. Please let us not start a discussion here (again) which opinion is right and which is wrong. I already apologize for marking HA´s original position values in red further down. People who come here in search for a solution are biased (I guess) and will understand.
Warnings and limitations:
As far as I understand there is still no 100% solution. I will also try to discribe these limits. Although I do all my automations in Node RED, in this case I use Template Covers. My solution does not have a tilt setting as my covers are not venetian blinds. If you need that, look deeper into the WTH discussion (and maybe add to this guide). My covers are based on the KNX integration of HA, but I guess it does not matter where the covers come from.
Now let’s start:
For each of your covers (and your cover groups) you need to create one inverted entity that controls the same cover but uses a percentage for 100 to 0 where the original cover uses 0 to 100. This is the config for the Template Cover entity cover.buro_inverted which is the mirror of the KNX cover cover.buro:
cover:
    covers:
      buro_inverted:
        friendly_name: Rolladen Büro
        position_template: "{{ 100 - state_attr('cover.buro', 'current_position') | int(default=0) }}"
        set_cover_position:
          service: cover.set_cover_position
            position: "{{ 100 - position }}"
            entity_id: cover.buro
        open_cover:
          service: cover.open_cover
          data: {}
        close_cover:
          service: cover.close_cover
          data: {}
        stop_cover:
          service: cover.stop_cover
          data: {}
        icon_template: >-
          {% if is_state('cover.buro', 'closed') %}
            mdi:window-shutter
          {% else %}
            mdi:window-shutter-open
          {% endif %}
Note 1: It is in fact possible that the inverted entitiy has the same friendly_name as the original entity! For example my covers are both named “Rolladen Büro”. This will later be helpful.
Note 2: You may notice that I invert the percentage of the inverted cover, but I do not invert the open / close service calls. You will definitely find examples in the forum, where these are inverted too (close_cover: calls cover.open_cover of the original entity and vice versa. I do not think that this makes any sense though. HA’s cover entities handle open and close perfectly and there is no discussion about that. We are talking about percentage values only here
Where to use?
The inverted entities are perfect to be used with HA’s voice assistants like Assist, Alexa and Google Home. They work perfectly here. Just go to Settings → Voice assistants → Expose, and deactivate the original cover entities and activate the inverted ones for all assistants. Done.
In Lovelace it is not so simple and here comes the current…
Limitation
In Lovelace you are stuck between a rock and a hard place:
  1. If you use the old entities, your percentage values are “wrong”.
  2. If you use the new entities, your slider in entity’s details view is wrong.
Example 1.: old entity when cover is nearly closed
Example 2.: new entity when cover is nearly closed
There are many solutions for that, mostly involving some kind of custom cards.
But the slider in the important details view itself will always stay “kaputt”, which is unacceptable for me.
So I personally prefer to live with 1. (the old, well known “wrong” percentage values) in most parts of Lovelace. But you can also mix and match as you like.
My major problem have always been the voice assistants, and they are perfectly taken care of by the new inverted entities.
Enjoy!
I have awnings (canopies) which extend outwards. The best paradigm for these would be “in/out”. Other people might prefer “up/down”, “open/closed”, “left/right”, “light/dark”… We also have vertical blinds, and it would be good to have consistency in the labels and paradigms. When we want to shut out the sun, the vertical blinds have to be Closed whereas the awning must be Open!
A simple-sounding structural solution would be to allow user-defined strings for 0% and 100%, or otherwise a choice of different paradigms (allowing for translations) together with an “invert” option.
But I have no idea how easy/difficult this would be to implement, or if it would have any undesirable side-effects.
I would prefer not to start another discussion about that here. There already is an extensive thread in the “What the heck…” section which I linked to in the guide above.
Pic shutter card (GitHub - samoswall/pic-shutter-card: Shutter card for Home Assistant Lovelace UI) has an option to simply invert the direction. Not a real solution for every purpose but perfect for me.
IMG_0190
Thank you,
That was very helpfull!!
Althought when I ask Alexa to set x rollershutter to 0% it executes 100%, what i’m doing wrong?
Up to 1% works good but when I ask Alexa to set 0% it execute 100%
Can we see your code?
Yes, thanks a lot
cover: !include covers.yaml
  covers:
    kitchen1_inverted:
      friendly_name: Kitchen 1
      unique_id: kitchen1_inverted_cover
      position_template: "{{ 100 - state_attr('cover.005_kitchen', 'current_position') | int(default=0) }}"
      set_cover_position:
          entity_id: cover.005_kitchen
      open_cover:
      close_cover:
      stop_cover:
      icon_template: >-
        {% if is_state('cover.005_kitchen', 'closed') %}
          mdi:window-shutter
        {% else %}
        {% endif %}
And the other thing now is that I can’t expose this entity to Alexa, It doesn’t show up in the Alexa app for a reason.
Alexa had cashed that particular entity… I fixed that.
Any suggestion?
I’m sorry Mike, I do not see any problem with your code. Did you check the Logbook to see which commands are issued?
I was having the same issues and got the following to work (currently v2025.3.4). Have 6 smartwings roller shades with Zigbee motor.
  1. Didn’t adjust anything with my Smartwings remote that came with them. I just used it to set the 0% and 100% points.
  2. Paired them with Zigbee2MQTT.
  3. For all of them, changed invert_cover to True (See Smartwings WM25L-Z control via MQTT | Zigbee2MQTT).
  4. In configuration.yaml added:
    covers:
      fixed_sunroom_shade_3:
        friendly_name: Fixed Sunroom Shade 3
        unique_id: fixed_sunroom_shade_3
        device_class: shade
        position_template: "{{ state_attr('cover.sunroom_shade_3', 'current_position') }}"
        value_template: >-
          {% set pos = state_attr('cover.sunroom_shade_3', 'current_position') | int %}
          {% if pos == 0 %}
            closed
          {% elif pos == 100 %}
            open
          {% else %}
            open
          {% endif %}
        open_cover:
          action: cover.open_cover
            entity_id: cover.sunroom_shade_3
        close_cover:
          action: cover.close_cover
        stop_cover:
          action: cover.stop_cover
        set_cover_position:
          action: cover.set_cover_position
            position: "{{ position }}"
Note that before this template I had the same behavior as you I believe. Between 1%-99% it said “open” and the correct percentage. Arrows and slider were the expected direction. But when fully closed it would revert to “open” state and vice versa. This fixed it for me.
Thank you so much for this! I recently got 13 smartwings shades, and didn’t see the value in spending 13x the price difference between zigbee and the other motor options. They generally work great, but the incorrect state was really starting to drive me crazy. Turned them all into template covers with your example and all is now right with the world.
Hey, fantastic to hear! It took me awhile to figure this out. I will say on two different occasions my shades stopped responding to my HAOS cover card calls to this template. I had to reboot Home Assistant for it to work again.
However, I’ve since realized I was running my phone on Nabu Casa cloud whenever at home by accident then, when I was trialing it. I’m wondering if there’s some weirdness with trying to do it through cloud.
I’m off the trial for now and all local again and haven’t seen those issues anymore, so I tend to think it was caused by the cloud connection and not my cover templates.
Let me know if you run into that issue, though, or if you come up with any other interesting solutions/add-ons here.
Have you had issues with totally losing Zigbee connectivity if you press “stop” on them mid open or close? Seems like I can do full open/full close buttons, and set the % open with the slider no issue. But if I press stop in the middle of it, I lose most of the cover connections until I fully reboot Z2MQTT. Had done some initial scoping and saw this is a common issue (using the stop_cover command), but haven’t gotten much further than that yet.
Hello @Jpsy ,
Thank you for sharing the invert cover template :pray:
I have a shade cover in my balcony.
WIth the current template, when I press the arrow up button in HA, the cover opens, and when I press the arrow down button, the cover closes.
Is there a way to switch the functions, so that when I press the arrow up button in HA, the cover will close, and when I press the arrow down button the cover will open?
Just wanted to share another thank you for this solution. It worked for my 5 new Smart wings shades.
