i followed the HookUp channel and happy to say i got it working.
sadly when it’s time to add into HA, i got error…
Invalid config for [cover.mqtt]: ‘value_template’ must be set together with ‘state_topic’… Got OrderedDict([(‘platform’, ‘mqtt’), (‘name’, ‘Roller 3’), (‘command_topic’, ‘/raw/esp8266/14521705/in’), (‘set_position_topic’, ‘/raw/esp8266/14521705/in’), (‘position_topic’, ‘/raw/esp8266/14521705/out’), (‘value_template’, ‘{{ value_json.position }}’), (‘json_attributes_topic’, ‘/raw/esp8266/14521705/out’), (‘json_attributes_template’, ‘{{ value_json.position | tojson }}’), (‘retain’, False), (‘payload_open’, ‘100’), (‘payload_close’, ‘0’), (‘position_open’, 100), (‘position_closed’, 0)]). (See /config/configuration.yaml, line 15). Please check the docs at MQTT - Home Assistant
cover:
- platform: mqtt
command_topic: "/raw/esp8266/14521705/in"
set_position_topic: "/raw/esp8266/14521705/in"
position_topic: "/raw/esp8266/14521705/out"
value_template: "{{ value_json.position }}"
json_attributes_topic: "/raw/esp8266/14521705/out"
json_attributes_template: "{{ value_json.position | tojson }}"
retain: false
payload_open: "100"
payload_close: "0"
position_open: 100
position_closed: 0
did something changed recently since his video?
