Hi
I have a (template) Cover for the garage door and wanted to change the icon based of 2 binary sensors (2 reed switch’s) one for open one for closed ?.
Here is the cover
The binay switchs are
binary_sensor.garage_door_is_closed and binary_sensor.garage_door_is_open they are either on/off to state if the door is closed or open
Thanks Andrew
Hi, No the sensor.garage_door doesn’t exist just the 2 binary sensors binary_sensor.garage_door_is_closed and binary_sensor.garage_door_is_open they are reed switchs
Hi arfrater,
how did you mount the two read switches?
Do you use Shelly 1?
I installed a Shelly 1 with a read switch on my garage door.
Is it possible to install two read switches on the Shelly 1?
Hi @Kabala
Its a DIY setup of ESP32 with esphome then i brought a few small reed switchs from eBay and wired it all together. The sensor monitors temp and has 2 PIR’s as well.
