Update, just made this work, but want to leave it here for others to be usefull.
Hi everybody, i am trying to use a modified sonoff basic to open and close the garage door or main gate and show the open state with a reed switch.
I know this has been mentioned many times before, the past few days i read almost everything about it i think. But i still can’t get it to work properly.
Here is what i have.
I modified a sonoff basic so that the relay acts independent from the incoming power.
So is it switches, it only makes a contact.
I programmed it wit the latest tasmota where i filled in the things needed for wifi and mqtt.
I also set a pulstime of 10 so that whenever i activate the switch it is only pulsing on for 1 second and then stays off again.
I set the mqtt topic to sonoffgate
I connected the reed switch to ground and GPIO14.
After starting the sonoff for the first time i set GPIO14 to 10switch2.
In the console I typed
switchmode1 0
switchmode2 2
switchtopic2 gatestate… This was my mistake, for some reason this does not work, this needs to be switchtopic2 2
When i test the buttons this shows up in the console
Switch
10:43:20 MQT: stat/sonoffgate/RESULT = {"POWER":"ON"} 10:43:20 MQT: stat/sonoffgate/POWER = ON 10:43:21 MQT: stat/sonoffgate/RESULT = {"POWER":"OFF"} 10:43:21 MQT: stat/sonoffgate/POWER = OFF
Reed switch
10:46:34 MQT: cmnd/gatestate/POWER2 = ON
10:46:38 MQT: cmnd/gatestate/POWER2 = OFF
So gatestate is now changed to 2, and gives me the same output
I made a binary_sensor in config.yaml like this.
binary_sensor:
- platform: mqtt
state_topic: "cmnd/gatestate/POWER2"
payload_on: "ON"
payload_off: "OFF"
This binary sensor is not needed for the cover to function correct but here i also changed gatestate to 2
This shows the state correct if i activate the reed switch so i assume this is working like it should.
I added this cover function in the config.yaml
cover: - platform: mqtt name: "test" state_topic: "cmnd/gatestate/POWER2" command_topic: "cmnd/sonoffgate/POWER" payload_open: "ON" payload_close: "ON" payload_stop: "ON" state_open: "ON" state_closed: "OFF" optimistic: false retain: false
Abobe I changed state_topic: “cmnd/gatestate/POWER2” changed to"cmnd/2/POWER2"
Added this in the customize.yaml
cover.test: friendly_name: front gate device_class: garage
At first i thought i would do this later, but it is an important step to make the mdi icon work and change. the line "device_class: garage"
sets the icon.
Added this in the groups.yaml
garage_doors: name: Main gate view: no control: hidden icon: mdi:garage entities: - cover.test
For some reason i don’t think that the icon line ads anything, but in all the examples i have seen its there.
I am tired of trying, maybe someone can tell why this should be here.
This is what my cover looks like in HA
Now when i click the black arrow, the relay switches like it should.
The same when i hit the black square.
So that is all good.
When i activate the reed switch, the mdi icon changes to an open garage door.
That is also like it should.
The thing that i am struggling with is that the grayed out arrow stays grayed out no matter what i do.
A already spent my complete weekend trying to figure this out but i can’t find the solution.
I hope that this can help others.
I am glad i finally made it work.
