Hi
I have a cover group with two shutters. One shutter is an RTS controlled Somfy shutter. This does not report back position - it’s receive only. The other shutter is a Velux shutter. This second shutter does report position (as a percentage).
When I add this cover group to my UI I get the Open, Stop, Close buttons.
If the Velux shutter is 100% open then the Open button is grayed out; if it’s 0% open then the Close button is grayed out. This means that I cannot use the group to open the RTS shutter if the Velux is already 100% open. (and vice versa if the Velux is Closed).
Is there a way to disable this automatic disabling of the controls based on a single group member’s position?
