Hi there!
I have a Zigbee smart blind switch, which shows up in Home Assistant as a cover. It has the following controls: Up, Stop, Down, Position:
The trouble I have is this switch has no concept of position, and the attribute is stuck at 100%. Because the position state is never set, it flicks straight back to 100% constantly and the “Up” button is thereby greyed out. It’s basically rendering the cover unusable.
The Zigbee device signature is:
"node_descriptor": "NodeDescriptor(byte1=1, byte2=64, mac_capability_flags=142, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0202",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0102"
"out_clusters": [
"0x0003"
"manufacturer": "Feibit Co.Ltd",
"model": "FB56+CUR17SB2.2",
"class": "zigpy.device.Device"
Is there any way to set the position from another sensor (which would be hard) or better yet just disable the position attribute?
Many thanks!
