Cover Icon not changing
I’m sure it’s something simple but I cannot get my Garage Door cover icon to change from the default cover icon.
customize.yaml:
cover.garage:
device_class: garage
icon: mdi:garage
friendly_name: Garage Door
google_assistant: true
google_assistant_type: switch
groups.yaml:
garage_doors:
view: no
control: hidden
entities:
- cover.garage
cover.yaml:
  • platform: mqtt
    state_topic: “cmnd/garage2/POWER2”
    command_topic: “cmnd/garage/POWER”
    payload_open: “ON”
    payload_close: “ON”
    payload_stop: “ON”
    state_open: “OFF”
    state_closed: “ON”
    optomistic: false
Remove the icon part from your customize.
Thanks for the reply. Removed the icon line but it still shows the default cover icon.
/config/customize.yaml:
cover.garage:
What shows up in the <> menu for cover.garage ?
cover.garage closed
supported_features: 11
Seems like it’s not using your customize.yaml at all.
Does the check config show any errors when you hit the button in Configuration > General ?
Ah I figured it out. I had added a zone component into the config file before my customization entry.
Thanks for your help.
Could you please show me your configuration.yaml, the part where zone is before your customization entry?
