MQTT cover retain message is not working.
my config is
cover Blinds:
- platform: mqtt
command_topic: "blinds/control/room1"
qos: 1
retain: true
payload_open: "UP"
payload_stop: "STOP"
payload_close: "DOWN"
if i click the buttons on the home Assistant front-end it dos not produce a retained message. Only send a normal message.
I’ve tested the switch mqtt with a similar config and it does send a retained message.
So this must be a bug introduced when migrating core code from rollershutter to cover.
EDIT: Issue opened in github: https://github.com/home-assistant/home-assistant/issues/3497
