I programmed a cover using Arduino on a esp8266. The cover post to MQTT this config:
device_class: shade
unique_id: rho1_cover
device:
identifiers: rho1
model: PLATFORMIO_D1_MINI
manufacturer: espressif
availability_topic: homeassistant/binary_sensor/connectivity/rho1/out
command_topic: homeassistant/cover/rho1/in
set_position_topic: homeassistant/cover/rho1/in
position_topic: homeassistant/cover/rho1/out
json_attributes_topic: homeassistant/cover/rho1/out
json_attributes_template: '{{ value_json.position | tojson }}'
payload_open: '0'
payload_close: '100'
value_template: '{{ value_json.position }}'
platform: mqtt
On MQTT I can see
out={ “set”:79, “position”:79 }
On the dashboard I use a
type: custom:slider-entity-row
On HA everything works perfect except showing the current position. When I open the dashboard, the slider is always at 0. Also if I check history it always shows Unknow as the state.
I think my MQTT config is not good, or maybe I should use 2 different topics for the set and position info, I can change my Arduino code, so maybe suggest the ideal MQTT I should use and I would change my code to follow along.
