Cover scrollbar
Just wanted to know how could I do this:
Just because I do not see the option in the covers documentacion.
Let me know,
Pedro
I think this depends on your hardware… does your hardware allow incremental changes to the orientation of your blinds? If so, what is the nomenclature?
FYI scrollbars are called input_number
It is mqtt blind, but the addon does not seem to have this feature :frowning:
I’m not sure where you got your info from, but from the mqtt cover component page, your request appears to be possible:
tilt_min
(integer)(Optional)The minimum tilt value.
Default value: 0
tilt_max
(integer)(Optional)The maximum tilt value
Default value: 100
tilt_closed_value
(integer)(Optional)The value that will be sent on a close_cover_tilt command.
Default value: 0
tilt_opened_value
(integer)(Optional)The value that will be sent on an open_cover_tilt command.
Default value: 0
You just need to specify a tilt to the mqtt topic. That tilt angle is what you link to the slider.
I have run into the same issue before.
The open/close slider does not appear as it does with other covers such as zwave cover.
The tilt slider does appear and does work once you assign a topic to it.
If thats the case, you just need to map the tilt to a slider, something like this:
- alias: Set Zone 1 Slider
    - platform: state
      entity_id: media_player.yamaha_receiver
  condition:
    - condition: template
      value_template: >
        {% if is_state('media_player.yamaha_receiver','off') %}
          true
        {% else %}
          {% if is_state_attr('media_player.yamaha_receiver', 'volume_level', states('input_number.yamaha_receiver') | int / 100) %}
            false
          {% else %}
            true
          {% endif %}
        {% endif %}
    - service: input_number.set_value
      entity_id: input_number.yamaha_receiver
      data_template:
        value: >
          {% if trigger.to_state.state == 'on' %}
            {% set n = trigger.to_state.attributes.volume_level | float %}
            {{ (n - 1.0)*100.0 | int }}
          {% else %}
            -80
          {% endif %}
- alias: Set Zone 1 Volume
    - platform: state
  condition:
      value_template: >
        {% if is_state('media_player.yamaha_receiver', 'on') %}
          {% if not is_state_attr('media_player.yamaha_receiver', 'volume_level', states('input_number.yamaha_receiver') | int / 100) %}
            true
          {% else %}
            false
          {% endif %}
        {% else %}
          false
        {% endif %}
    - service: media_player.volume_set
      data_template:
        volume_level: >
          {% set n = states('input_number.yamaha_receiver') | float %}
          {{ n / 100 + 1 }}
The difference is that you would trigger off the mqtt device changes instead of what I have listed in this automation. You could even convert your slider from 0-100 to whatever the min/max of the device is.
