I’m having problems with the cover service, here the error and my configuration:
Error:
INFO:homeassistant.util.package:Attempting install of colorlog==3.1.4
Testing configuration at /config
ERROR:homeassistant.util.yaml:while parsing a block collection
in “/config/cover.yaml”, line 2, column 5
expected , but found ‘?’
in “/config/cover.yaml”, line 3, column 5
Failed config
General Errors:
- Error loading /config/configuration.yaml: while parsing a block collection
But just as a guess, I would say that you don’t have the proper indentation but without the code being properly formatted there is no way I can tell you exactly where the problem is.
It worked, the problem was only in the cover.yaml in the configuration.yaml It works like I pasted here.
So if I understand (my mother language is not english) the indentations is the structure of the code?
But why in the cover.yaml I have the problem and not in the configuration.yaml?
