I would like to set the cover position depending on the current_position. I struggle to format correctly the code.
domain: cover
entity_id: cover.rho1_cover
type: set_position
position: >-
{% if state_attr('cover.rho1_cover', 'current_position') | int == 100 %}
0
{% else %}
100
{% endif %}
My code here doesn’t work, pretty sure is the formatting
wmaker
(Tommy Long)
September 21, 2021, 4:46pm
2
Here is what I do sometimes…Goto the UI->Developer Tools->Services
then select the service, in this case: cover.set_cover_position
Then goto “UI Mode” where it will help provide the needed information that you can fill out, like selecting your entity and position value, then go back to “YAML Mode”.
It will show you something like the following:
service: cover.set_cover_position
position: 51
entity_id: cover.bonus_room_blinds
I haven’t used set_cover_position before, but I think the following template will work for you…
Since you want to use a template for the position
, you would probably use position_template
instead. The template may look something like:
position_template: >-
{% if is_state_attr('cover.rho1_cover', 'current_position', 100) %}
0
{%- else -%}
100
{%- endif %}
When I try with the developper tools I get:
Failed to call service cover/set_cover_position. expected int for dictionary value @ data[‘position’]
So it seems it doesn’t recognize the 0 or 100 as int ? I also tried with position_template, it says extra keys not allowed on position_template
position: >-
0
{%- else -%}
100
{%- endif %}
Dujith
(Charles Evers)
September 21, 2021, 5:36pm
4
In developer tools: States
When you put in entity: cover.rho1_cover
What does the state attributes say?
My Zigbee controller says this:
current_position: 100
calibration: 'OFF'
calibration_time: 38.3
linkquality: 231
motor_reversal: 'ON'
moving: STOP
position: 100
friendly_name: Zonwering Woonkamer
supported_features: 15
developper: State for rho1_cover:
State: open
current_position: 4
friendly_name: Store chambre
device_class: shade
I made it work, changing the domain:cover and type: set_position to a call service as below.
position: |-
0
{% else %}
100
{% endif %}
Faecon
(Jo)
June 9, 2023, 8:15am
7
Is it possible to give a cover a standard maximum opening for like 80% ?
