I have a following template for my covers and blinds:
cover:
covers:
bedroom_blinds:
device_class: blind
friendly_name: "Bedroom Blinds"
unique_id: bedroom_blinds
open_cover:
service: rest_command.grenton_update_cover
object: "ROL_SYPIALNIA_ZALUZJA"
value: "0"
action: "open"
close_cover:
value: "0"
action: "close"
stop_cover:
value: "0"
action: "stop"
set_cover_position:
value: "{{position}}"
action: "set_position"
set_cover_tilt_position:
value: "{{tilt}}"
action: "set_tilt"
And then following rest command that is used to control the cover:
rest_command:
grenton_update_cover:
url: http://192.168.0.11/HA_Listener
method: POST
headers:
accept: "application/json"
payload: '{"type":"cover", "object":"{{object}}", "action":"{{action}}", "value": "{{value}}"}'
content_type: "application/json"
verify_ssl: false
When I run the rest_command service, then the cover responds as expected, it goes up/down, changes tilt angle etc. as expected.
However, when I try to run any of the cover services it fails to find the referenced device. This happens e.g. when pressing any of the cover buttons on my home dashboard.
Logger: homeassistant.helpers.service
Source: helpers/service.py:796
First occurred: 15:22:20 (15 occurrences)
Last logged: 16:12:28
Unable to find referenced entities cover.bedroom_blinds or it is/they are currently not available
This setup used to work on 2023.6 version of the Home Assistant. Stopped working after installing Z-Wave integration on 2023.7, but removing it does not help anyway. Downgrading to 2023.6 also didn’t help.
The same configuration works for another blind that is configured in a following way, i.e. I can use cover services on it:
cover:
covers:
bedroom_shade:
device_class: shade
friendly_name: "Bedroom Shades"
unique_id: bedroom_shade
open_cover:
object: "ROL_SYPIALNIA_ROLETA"
position: "0"
action: "open"
close_cover:
position: "0"
action: "close"
stop_cover:
position: "0"
action: "stop"
set_cover_position:
What else can I do to troubleshoot the issue? What can I do to fix it?
