Hi All,
So after all of the MyQ shenanigans I set out to recreate the functionality without dependence on Liftmaster. My solution was to take an extra garage door remote, solder on wires to the correct contacts (Main Garage door and the 2nd garage door) I then hooked those wires up to a Zooz Multirelay and was able to successfully trigger the garage doors. Next I followed the steps for the Cover Template and have it almost perfect but two requirements that I can’t seem to figure out.
Switch off the up arrow or down arrow when pressed. For example, in the screenshot below if I push the up arrow to open the garage, I get no feedback that the command was accepted and is in progress. It’s only when the garage is all the way up and the tilt sensor is triggered after ~10 seconds that the state changes. How to solve for this?
The stop button should only be active for the ~10 seconds that the garage is opening or closing. Since the command in the background is just essentially pushing the button on the door remote if the garage is up and you hit stop it actually opens the garage. It would be better if the button only activated while the garage was in motion. This could perhaps be time based. Maybe if I press the up arrow disable that button for 10 seconds and enable stop button? Coding for that is a little outside of my skill level though.
Here is the current YAML from my config
cover:
covers:
garage_main:
device_class: garage
friendly_name: "Garage Main"
value_template: "{{is_state('binary_sensor.garage_overhead_main', 'on')}}"
open_cover:
- condition: state
entity_id: binary_sensor.garage_overhead_main
state: "off"
- service: switch.turn_on
entity_id: switch.multirelay_2
close_cover:
- condition: state
state: "on"
stop_cover:
icon_template: >-
{% if is_state('binary_sensor.garage_overhead_main', 'off') %}
mdi:garage
{% else %}
mdi:garage-open
{% endif %}
garage_2:
friendly_name: "Garage Two"
value_template: "{{is_state('binary_sensor.garage_overhead_2', 'on')}}"
open_cover:
- condition: state
entity_id: binary_sensor.garage_overhead_2
state: "off"
entity_id: switch.multirelay_3
close_cover:
- condition: state
state: "on"
stop_cover:
icon_template: >-
{% if is_state('binary_sensor.garage_overhead_2', 'off') %}
mdi:garage
{% else %}
mdi:garage-open
{% endif %}
