duceduc
December 30, 2020, 9:55am
1
I am trying to setup a cover template but am confuse of what to add to the set cover position
. This is my current setting and both the open and close work. What do I need to add to the set_cover_position part?
covers:
computer_room_curtains:
device_class: curtain
friendly_name: "Computer Room Curtains"
position_template: "{{ states('sensor.cr_curtain_left_position') }}"
open_cover:
service: switch.turn_on
entity_id: switch.computer_room_curtains
close_cover:
service: switch.turn_off
set_cover_position:
service:
entity_id:
position:
icon_template: >-
{% if states('sensor.cr_curtain_left_position')|float < 90 %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
switch.yaml
- platform: command_line
switches:
friendly_name: Computer Room Curtains
command_on: 'curl -k "http://192.168.1.30:5004/?id=c5c6df6834df&cmd=open"'
command_off: 'curl -k "http://192.168.1.30:5004/?id=c5c6df6834df&cmd=close"'
computer_room_curtains_position:
friendly_name: Computer Room Curtains Position
command_on: 'curl -k "http://192.168.1.30:5004/?id=c5c6df6834df&cmd=pos&set={{position}}"'
command_off: 'curl -k "http://192.168.1.30:5004/?id=c5c6df6834df&cmd=pos&set={{position}}"'
duceduc
December 30, 2020, 11:39am
2
I got it working now. This thread gave me a clue as to what I needed to set up the cover position. The switch method would not work but a shell command
would.
shell command:
computer_room_curtains_position: 'curl -k "http://192.168.1.30:5004/?id=c5c6df9448bc&cmd=pos&set={{position}}"'
cover:
covers:
open_cover:
close_cover:
set_cover_position:
service: shell_command.computer_room_curtains_position
data_template:
position: "{{ position }}"
icon_template: >-
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
duceduc
December 30, 2020, 9:46pm
3
Now that I got the cover template working, I notice the state (open
| closed
) does not change when the curtains opens or closes. I think that is because the position number do not indicate as fully open (0) or closed (100). It hovers around 2 or 97.
Also my device reads the opposite. HA reads fully open as (100) and fully closed as (0).
Update :
After some more searching and tinkering with the code, I have got my curtains to read and trigger proper.
covers:
value_template: >-
open
{% else %}
closed
{% endif %}
open_cover:
close_cover:
set_cover_position:
data_template:
icon_template: >-
{% if is_state('cover.computer_room_curtains', 'open') %}
mdi:blinds-open
{% else %}
mdi:blinds
{% endif %}
