I have to tags:
From home assistant to PLC - input_number.rol_goscinny1_poz - which sending new cover position to PLC
From PLC to HA - input_number.rol_goscinny1_poz_feedback - which giving to home assistant information about current position of cover.
Now its working like that - I need additional slider below cover because original slider is not working.
And I have now now Idea how to push template to work with my tags to PLC…
How is the input_number.rol_goscinny1_poz_feedback getting populated? Is this number just to store the last value you sent to the shutter? Are you just trying to make an input number control your cover?
input_number.rol_goscinny1_poz_feedback is from current real position of shutter from PLC. So if you move shutter up or down position from wall button - it will also change, so its updated when real position of shutter change.
