I try to configure cover template but its not working. In log file I have this:
2017-07-03 10:37:00 ERROR (MainThread) [homeassistant.components.cover.template] No covers added
Ok it is working. But I do not need the state of the cover. How can I configure this without taking state cover into account? I’m using relays to control my blinds so I cant check position of my blinds.
Is there a way to setup a timer to enable the use of the position slider. For instance, if we know the opening and closing time of the cover, we can use that information and the initial position information to set any position we want.
Covers use state to determine what functions are available. If it’s up, the down button is active. If it’s down, the up button is active. It also uses state to determine what icon to show.
You could set the state to a fixed value I suppose, but you lose much of the functionality of the cover. You would be just as well off to add an input_boolean to control your cover.
