psyciknz
(Psyciknz)
April 25, 2019, 5:26am
1
I have an mqtt cover that uses a PGM command on my alarm to open and close it. The command though, is ON. Ie if door is close, ON will start it opening. Once the door is open, ON again will close it. So it’s a momentary switch I guess.
How can I sent the ON command regardless, but once the command is passed, set it back to OFF.
Here’s the config:
- platform: mqtt
state_topic: "sensors/d1mini/garage-sensor/reed/state"
command_topic: "Paradox/C/PO/1"
availability_topic: "sensors/d1mini/garage-sensor/$online"
payload_available: "true"
payload_not_available: "false"
payload_open: "on"
payload_close: "on"
device_class: "garage"
psyciknz
(Psyciknz)
April 25, 2019, 5:36am
2
Hmm not to worry…it actually works anyway. I just need to remember to add a little delay between opening and closing.
I have the Paradox alarm working on HA but only to switch on and off the alarm.
Are you using the PGM of Paradox from HA?
psyciknz
(Psyciknz)
May 27, 2019, 12:02am
4
Yes. Using a different service to above, but similar.
Using: https://github.com/jpbarraca/pai now so the command line is a little different, but its pretty close.
Is the installation on hassio like this?
Manually
Download the files in this repository and place it in some directory
git clone https://github.com/jpbarraca/pai.git
Copy config/pai.conf.example
to /etc/pai/pai.conf
and edit it to match your setup. The file uses Python syntax.
mkdir -p /etc/pai
cp config/pai.conf.example /etc/pai/pai.conf
edit /etc/pai/pai.conf as needed
python3 run.py
Alternatively see #Configuration section for supported file locations.
Install the python 3.6 and its requirements.
pip3 install -r requirements.txt
psyciknz
(Psyciknz)
May 27, 2019, 7:11pm
6
I don’t know hassio sorry. I use a home assistant docker container on an ubuntu machine…so pai is running in docker as well.
Isn’t docker hidden from you in hassio?
https://hub.docker.com/r/jpbarraca/pai
And have mqtt running somewhere as well.
