Covers MQTT issue
I want to command two covers with MQTT
This is my config.yamlcover:
cover:
  - platform: mqtt
    command_topic: "rolluikenbeneden"
    state_topic: "rolluikenbenedenconfirm"
    qos: 0
    payload_open: "1"
    payload_stop: "2"
    payload_close: "3"
    state_open: "Open"
    state_closed: "Dicht"
  - platform: mqtt
    qos: 0
    payload_open: "4"
    payload_stop: "5"
    payload_close: "6"
    state_open: "Open"
The first part (Rolluiken Hoek) works fine but the second part (Rolluiken Voor) don’t.
I have them show up in UI and if i click on the up or down command of “Rolluiken Hoek” the payload sends out.
If i click on the up or down command of “Rolluiken Voor” nothing happens.
What did i do wrong?
If these are two separate covers then each one should have its own unique command_topic and state_topic.
Rolluiken Voor uses a different command_topic from Rolluiken Hoek (good) but it uses the same state_topic (not good).
Solved,
Thanks for the tip.
