I configured two covers in HA driven by a couple of Shelly 2.5
They worked fine untile last HA restart.
Now I can see the entities but if I try to open/close them nothing happens. I cannot see the message in MQTT server too.
Here you are my config:
- platform: group
entities:
- cover.tapparella_camera
- cover.tapparella_cameretta
- platform: mqtt
unique_id: "tapparella_camera"
state_topic: "shellies/shellyswitch25-E66CFA/roller/0"
command_topic: "shellies/shellyswitch25-E66CFA/roller/0/command"
position_topic: "shellies/shellyswitch25-E66CFA/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-E66CFA/roller/0/commnad/pos"
availability_topic: "shellies/shellyswitch25-E66CFA/online"
payload_available: "true"
payload_not_available: "false"
payload_open: "open"
payload_close: "close"
payload_stop: "stop"
state_open: "open"
state_closed: "close"
retain: true
optimistic: false
qos: 0
position_open: 100
position_closed: 0
value_template: '{{ value.x }}'
- platform: mqtt
unique_id: "tapparella_cameretta"
name: "Tapparella cameretta"
state_topic: "shellies/shellyswitch25-00B763/roller/0"
command_topic: "shellies/shellyswitch25-00B763/roller/0/command"
position_topic: "shellies/shellyswitch25-00B763/roller/0/pos"
set_position_topic: "shellies/shellyswitch25-00B763/roller/0/commnad/pos"
availability_topic: "shellies/shellyswitch25-00B763/online"
state_open: "open"
retain: true
optimistic: false
qos: 0
position_open: 100
position_closed: 0
in HA logs I can see only some warnings like:
WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
No other errors.
What could be the problem?
