htop consistently shows process python3 homeassistant is consuming 100% of available CPU, a few hours after device boots.
While CPU is at 100%, hass response to the user is sluggish to the point of being unusable.
CPU consumption remains at 100% until device is restarted.
On restart, hass performs great again, and CPU consumption resets back to a few percent.
CPU gradually increases and then jumps back up to 100% again after a few hours.
hass is running on a pi-3 device as Core inside the standard Docker container. Installed using the default instructions. Installed with the April 2023 release.
I’m keen to keep using the pi for other things in tandem with hass, so need to avoid the HAOS approach.
Any tips on what might be causing the problem?
This chart illustrates the problem. Red is total CPU consumed by all processess. Blue is homeassistant process. Device is reset at 05:00.
