CPU incrise since maj supervisor 2024.8.0
I just upgrade the supervisor to 2024.8.0. Since the reboot my virtual machine use x5 more CPU than before :
Someone has the same issue ? Where can I look where is the issue ? I see noting in log.
I use à VM nuc in Proxmox with HAOS.
If you just upgraded and use the recorder database on the same host, you are looking at a database migration. See the topmost ‘backwards incompatible change’ in the release notes.
PS. Why update to 2024.8.0 if a patch release 2024.8.1 is already released?
Thanks for your answer but it’s not the core update but the supervisor.
Ah, sorry. Misread!
Ok nothing to do with supervisor… It’s rigtomqtt. Don’t understand why it doesn’t start correctly on boot since the last update.
