I upgraded from Core 2023.11 to 2024.1.2 and had to # my ping config in configuration.yaml. Now the CPU temperature isn’t reading. I can’t work out what is wrong, and C&P the code into the Developer Tool Template doesn’t make it work either ! So it’s something deeper that I can’t work out.
The CPU reading has worked fine for years previously to this update. It also doesn’t work with lines 13 to 18 un# either and works ok again if I roll it back.
Not sure how to upload code into a topic, so here’s a screenshot instead.
is also deprecated. Comment the entry in your configuration.yaml and restart HA. Then go to Integrations, there should be automatically appear „System Monitor“
Thanks for your replies, help and suggestions. Nothing seems to work to resolve this so I have rolled back to 2023.11, and I’ll keep it there since it works as intended until I can find more information.
@pedolsky I C&P the new code for the CPU T into the Template and received an error:
