CPU temperature Raspberry Pi
Hello everyone,
I have the following problem. I added this code to the sensors.yaml:
  • platform: command_line
    sensors:
    cpu_temparature:
    command: “cat /sys/class/thermal/thermal_zone0/temp”
    unit_of_measurement: “°C”
    value_template: “{{ value | multiply(0.001) | round(1) }}”
I receive the following error:
Invalid config for [sensor.command_line]: [sensors] is an invalid option for [sensor.command_line]. Check: sensor.command_line->sensors. (See ?, line ?).
What are I doing wrong?
Thank you for your answers.
For the pi, just use this:
or this: GitHub - ironsheep/lovelace-rpi-monitor-card: A Raspberry Pi status display Card for Home Assistant Lovelace :wink:
am I right in thinking that won’t work for Hass OS?
I don’t know, not sure, how much HAOS allows you to do…
