I had my setup with plain homeassistant on an arm board.
After migrating to hass.io on intel, the systemmonitor sensors are no longer avaliable
A few of those items were renamed a few updates ago… it was listed in the breaking changes section for one of the updates not sure if that may be what you are running into… https://www.home-assistant.io/components/sensor.systemmonitor/
Thanks for the reply.
The sensors were working in homeassistant 0.62, with the same config. I have checked the syntax and it appears to be ok.
I’ll also check on github
You where right, this sensor (systemmonitor) changed its name on 0.63: https://www.home-assistant.io/blog/2018/02/10/release-63/#breaking-changes
The problem wasn’t in the sensor definition, but in the reference to the sensor in the groups!
Thanks for your advice!
