My Home assistant sometimes consumes more CPU than the day before without an obvious reason. I also know that e.g. switching on the camera for the vacuum robot bring cpu usage up (That why I had to implement an automated disabling of the camery entity when the robot is docked). What I would like to know: which core functions / integrations / automations etc. are consuming the CPU. Even in an ideal scenario, when HA is idle the usage is at around 3%, which is not a drama, but I would like to have an overview what is going in there (approx. every 10s the usage goes up to 8% - I suppose it’S the scheduler firing the template entities to be refreshed or the automations checked looking after the automations that might be triggered or even automotation fired - But I have no clue if it’s the case)
Also the memory consumption is quite high. Not sure if it would be possible to have a similar overview there - 620MB memory consumption on a raspi is quite a lot for a python-engined application?
see, that’s the point. I’ve installed the profiler and let it run. and now I have 2 files sitting there. how I can now figure out where the cpu is used - without having studied computer science. And I can tell you I have studied it - and still have no clue how to evaluate the result. Home assistant should provide a proper UI for that - IMO
It can show you how much memory, cpu, network and IO each add-on is using in real time. Not as specific as which automation, but it might be a place to start.
hmm, I see it differently. But I also get your point. And since it’s not really critical, I’m ok with moving it into a discussion room. I’m not going to spend time on it though anymore. IMO, HA could have such a dashboard built in, but it’s probably not very urgent as of now. Thanks for the hints though! shouldn’t be blaming from my side. I just tend to give up if the things don’t work from scratch. HA has been a very nice application so far. I’m very happy with it and also with the community here. I do appreciate the answers. maybe it doesn’t sound like that in writing sometimes… hence once again: thanks for pointing to the integrations.
