I need help !
I crashed hassio probably because of miss config during duckdns config.
Hassio is installed on docker
I de active auto restart hassio,
remove all containers and images
and install again (from scratch)
Now the hassio start, but I have no web ui running.
Here is the container list
sudo docker container list
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
7f899f7e93cc homeassistant/intel-nuc-homeassistant:0.99.2 "/bin/entry.sh pytho…" 35 minutes ago Up 35 minutes homeassistant
741927707adf homeassistant/amd64-hassio-dns:1 "coredns -conf /conf…" 37 minutes ago Up 37 minutes hassio_dns
60b78d7a070e homeassistant/amd64-hassio-supervisor "/bin/entry.sh pytho…" 42 minutes ago Up 37 minutes hassio_supervisor
In the homeassistant container log I see logs from my old confg ! it is not from scratch !
How can i restore config from scratch or solve the web ui ?
the port 8123 is open (nmap)
what i don’t understand is:
I stop hass services
I remove all docker container
I remove all images
I re install hass on docker
and…
I receive a mail from hass automation from my old config !
Is that possible to re install from scratch ? or modify scripts from docker ?
I am near to re install the machine…
very disapointed…
it seems we have to exec into the homeassistant docker container to find the problem.
the command is : # docker container exec homeassistant /bin/bash
after this you will find yourself within the container
and you could still see logs from outside of the container using: # docker logs homeassistant
I am suspecting a malfunctioning component halt the startup and HA just stop .
I’m not the one with the issue. The OP asked to start over from scratch and doesn’t realize the files are on the host and just need to be moved/deleted. The OP can either look at the log file and fix the issue, or delete/move the config directory files and start over.
@vormsty if you are using hassio then the default location for homeassistant /config folder on the host machine would be /mnt/data/supervisor/homeassistant
thanks for your reply.
I understand after rebuilded my machine that because I installed duckdns and my router is not able to forward, I can’t join the machine from local network.
If samba is not installed, hassio became unrechable from my knoledge…
May be an remark can help many beginners…
