Crash when installing latest Home Assistant on Mac Mini M1 VB 7
I’m trying to install Home Assistant in a Virtual box on a Mac Mini M1.
OS: Ventura 13.1 (22C65)
HA: haos_ova-9.4.vdi
Virtual Box: Version 7.0.6_BETA4 r155176 (Qt6.3.0
Following these instructions: MacOS - Home Assistant
Every time I try to boot the VM, it starts booting but the VM crashes at or just after “run /sbin/init as init process”
Any suggestions? I’ve used VMs before, and I’m not sure what I could be doing wrong here.
VBox Log
00.588537 VirtualBox VM 7.0.6_BETA4 r155176 darwin.arm64 (Jan 11 2023 15:33:16) release log
00:00:00.588538 Log opened 2023-01-28T18:39:52.707800000Z
00:00:00.588539 Build Type: release
00:00:00.588546 OS Product: Darwin
00:00:00.588548 OS Release: 22.2.0
00:00:00.588551 OS Version: Darwin Kernel Version 22.2.0: Fri Nov 11 02:04:44 PST 2022; root:xnu-8792.61.2~4/RELEASE_ARM64_T8103
00:00:00.588595 Firmware type: failed - VERR_NOT_SUPPORTED
00:00:00.588606 Host RAM: 8192MB (8.0GB) total, 2082MB (2.0GB) available
00:00:00.588608 Executable: /Applications/VirtualBox.app/Contents/MacOS/VirtualBoxVM
00:00:00.588608 Process ID: 3005
00:00:00.588608 Package type: DARWIN_64BITS_GENERIC
00:00:00.589463 Installed Extension Packs:
00:00:00.589472   Oracle VM VirtualBox Extension Pack (Version: 7.0.6 r155176; VRDE Module: VBoxVRDP; Crypto Module: VBoxPuelCrypto)
00:00:00.590046 Console: Machine state changed to 'Starting'
00:00:00.590148 Qt version: 6.3.0
00:00:00.591915 SUP: In driverless mode.
00:00:00.593204 Guest OS type: 'Linux26_64'
00:00:00.593887 fHMForced=true - No raw-mode support in this build!
00:00:00.599630 File system of '/Users/stephenchurchill/VirtualBox VMs/HA/haos_ova-9.4.vdi' is apfs
00:00:00.612588 Audio: Detected default audio driver type is 'CoreAudio'
00:00:00.618909 Shared Clipboard: Service loaded
00:00:00.618918 Shared Clipboard: Mode: Off
00:00:00.618960 Shared Clipboard: Service running in normal mode
00:00:00.620159 Drag and drop service loaded
00:00:00.620165 Drag and drop mode: Off
00:00:00.622032 ************************* CFGM dump *************************
00:00:00.622128 [/] (level 0)
00:00:00.622130   CpuExecutionCap   <integer> = 0x0000000000000064 (100)
00:00:00.622131   EnablePAE         <integer> = 0x0000000000000001 (1)
00:00:00.622131   HMEnabled         <integer> = 0x0000000000000001 (1)
00:00:00.622132   MemBalloonSize    <integer> = 0x0000000000000000 (0, 0 B)
00:00:00.622133   Name              <string>  = "HA" (cb=3)
00:00:00.622133   NumCPUs           <integer> = 0x0000000000000001 (1)
00:00:00.622134   PageFusionAllowed <integer> = 0x0000000000000000 (0)
00:00:00.622134   RamHoleSize       <integer> = 0x0000000020000000 (536 870 912, 512.0 MiB)
00:00:00.622135   RamSize           <integer> = 0x0000000103000000 (4 345 298 944, 4.0 GiB)
00:00:00.622136   TimerMillies      <integer> = 0x000000000000000a (10)
00:00:00.622136   UUID              <bytes>   = "69 96 91 e9 9f e6 ef 40 91 dd 4a fa cc 83 52 ef" (cb=16)
00:00:00.622137
00:00:00.622137 [/CPUM/] (level 1)
00:00:00.622138   Enable64bit        <integer> = 0x0000000000000001 (1)
00:00:00.622138   GuestCpuName       <string>  = "host" (cb=5)
00:00:00.622139   NestedHWVirt       <integer> = 0x0000000000000000 (0)
00:00:00.622139   PortableCpuIdLevel <integer> = 0x0000000000000000 (0)
00:00:00.622139   SpecCtrl           <integer> = 0x0000000000000000 (0)
00:00:00.622140
00:00:00.622140 [/CPUM/IsaExts/] (level 2)
00:00:00.622140
00:00:00.622140 [/DBGC/] (level 1)
00:00:00.622141   GlobalInitScript <string>  = "/Users/stephenchurchill/Library/VirtualBox/dbgc-init" (cb=53)
00:00:00.622141   HistoryFile      <string>  = "/Users/stephenchurchill/Library/VirtualBox/dbgc-history" (cb=56)
00:00:00.622141   LocalInitScript  <string>  = "/Users/stephenchurchill/VirtualBox VMs/HA/dbgc-init" (cb=52)
00:00:00.622142
00:00:00.622142 [/DBGF/] (level 1)
00:00:00.622142   Path <string>  = "/Users/stephenchurchill/VirtualBox VMs/HA/debug/;/Users/stephenchurchill/VirtualBox VMs/HA/;cache*/Users/stephenchurchill/VirtualBox VMs/HA/dbgcache/;/Users/stephenchurchill/" (cb=175)
00:00:00.622142
00:00:00.622142 [/Devices/] (level 1)
00:00:00.622143
00:00:00.622143 [/Devices/3c501/] (level 2)
00:00:00.622143
00:00:00.622143 [/Devices/8237A/] (level 2)
00:00:00.622143
00:00:00.622143 [/Devices/8237A/0/] (level 3)
00:00:00.622144   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622144
00:00:00.622144 [/Devices/GIMDev/] (level 2)
00:00:00.622145
00:00:00.622145 [/Devices/GIMDev/0/] (level 3)
00:00:00.622145   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622145
00:00:00.622145 [/Devices/VMMDev/] (level 2)
00:00:00.622146
00:00:00.622146 [/Devices/VMMDev/0/] (level 3)
00:00:00.622146   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622147   PCIDeviceNo   <integer> = 0x0000000000000004 (4)
00:00:00.622147   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622147   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622147
00:00:00.622147 [/Devices/VMMDev/0/Config/] (level 4)
00:00:00.622148   GuestCoreDumpDir <string>  = "/Users/stephenchurchill/VirtualBox VMs/HA/Snapshots" (cb=52)
00:00:00.622148
00:00:00.622148 [/Devices/VMMDev/0/LUN#0/] (level 4)
00:00:00.622149   Driver <string>  = "HGCM" (cb=5)
00:00:00.622149
00:00:00.622149 [/Devices/VMMDev/0/LUN#0/Config/] (level 5)
00:00:00.622149
00:00:00.622150 [/Devices/VMMDev/0/LUN#999/] (level 4)
00:00:00.622150   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622150
00:00:00.622150 [/Devices/VMMDev/0/LUN#999/Config/] (level 5)
00:00:00.622151   First                <integer> = 0x0000000000000000 (0)
00:00:00.622151   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:00.622151   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622152   iLedSet              <integer> = 0x0000000000000006 (6)
00:00:00.622152
00:00:00.622152 [/Devices/acpi/] (level 2)
00:00:00.622152
00:00:00.622153 [/Devices/acpi/0/] (level 3)
00:00:00.622153   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622153   PCIDeviceNo   <integer> = 0x0000000000000007 (7)
00:00:00.622153   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622154   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622154
00:00:00.622154 [/Devices/acpi/0/Config/] (level 4)
00:00:00.622154   CpuHotPlug          <integer> = 0x0000000000000000 (0)
00:00:00.622155   FdcEnabled          <integer> = 0x0000000000000000 (0)
00:00:00.622155   HostBusPciAddress   <integer> = 0x0000000000000000 (0)
00:00:00.622155   HpetEnabled         <integer> = 0x0000000000000000 (0)
00:00:00.622156   IOAPIC              <integer> = 0x0000000000000001 (1)
00:00:00.622156   IocPciAddress       <integer> = 0x0000000000010000 (65 536)
00:00:00.622156   NumCPUs             <integer> = 0x0000000000000001 (1)
00:00:00.622157   Parallel0IoPortBase <integer> = 0x0000000000000000 (0)
00:00:00.622157   Parallel0Irq        <integer> = 0x0000000000000000 (0)
00:00:00.622157   Parallel1IoPortBase <integer> = 0x0000000000000000 (0)
00:00:00.622157   Parallel1Irq        <integer> = 0x0000000000000000 (0)
00:00:00.622158   Serial0IoPortBase   <integer> = 0x0000000000000000 (0)
00:00:00.622158   Serial0Irq          <integer> = 0x0000000000000000 (0)
00:00:00.622158   Serial1IoPortBase   <integer> = 0x0000000000000000 (0)
00:00:00.622158   Serial1Irq          <integer> = 0x0000000000000000 (0)
00:00:00.622159   ShowCpu             <integer> = 0x0000000000000001 (1)
00:00:00.622159   ShowRtc             <integer> = 0x0000000000000000 (0)
00:00:00.622159   SmcEnabled          <integer> = 0x0000000000000000 (0)
00:00:00.622160
00:00:00.622160 [/Devices/acpi/0/LUN#0/] (level 4)
00:00:00.622160   Driver <string>  = "ACPIHost" (cb=9)
00:00:00.622160
00:00:00.622160 [/Devices/acpi/0/LUN#0/Config/] (level 5)
00:00:00.622161
00:00:00.622161 [/Devices/ahci/] (level 2)
00:00:00.622161
00:00:00.622161 [/Devices/ahci/0/] (level 3)
00:00:00.622162   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622162   PCIDeviceNo   <integer> = 0x000000000000000d (13)
00:00:00.622162   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622163   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622163
00:00:00.622163 [/Devices/ahci/0/Config/] (level 4)
00:00:00.622163   Bootable  <integer> = 0x0000000000000001 (1)
00:00:00.622164   PortCount <integer> = 0x0000000000000001 (1)
00:00:00.622164
00:00:00.622164 [/Devices/ahci/0/Config/Port0/] (level 5)
00:00:00.622164   Hotpluggable <integer> = 0x0000000000000000 (0)
00:00:00.622165
00:00:00.622165 [/Devices/ahci/0/LUN#0/] (level 4)
00:00:00.622165   Driver <string>  = "VD" (cb=3)
00:00:00.622165
00:00:00.622165 [/Devices/ahci/0/LUN#0/Config/] (level 5)
00:00:00.622166   BlockCache <integer> = 0x0000000000000001 (1)
00:00:00.622166   Format     <string>  = "VDI" (cb=4)
00:00:00.622167   Mountable  <integer> = 0x0000000000000000 (0)
00:00:00.622167   Path       <string>  = "/Users/stephenchurchill/VirtualBox VMs/HA/haos_ova-9.4.vdi" (cb=59)
00:00:00.622167   Type       <string>  = "HardDisk" (cb=9)
00:00:00.622168   UseNewIo   <integer> = 0x0000000000000001 (1)
00:00:00.622168
00:00:00.622168 [/Devices/ahci/0/LUN#0/Config/Plugins/] (level 6)
00:00:00.622168
00:00:00.622168 [/Devices/ahci/0/LUN#0/Config/Plugins/VDPluginCrypt/] (level 7)
00:00:00.622169   Path <string>  = "/Applications/VirtualBox.app/Contents/MacOS/ExtensionPacks/Oracle_VM_VirtualBox_Extension_Pack/darwin.arm64/VDPluginCrypt.dylib" (cb=128)
00:00:00.622169
00:00:00.622170 [/Devices/ahci/0/LUN#0/Config/VDConfig/] (level 6)
00:00:00.622170   AllocationBlockSize <string>  = "1048576" (cb=8)
00:00:00.622170
00:00:00.622170 [/Devices/ahci/0/LUN#999/] (level 4)
00:00:00.622171   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622171
00:00:00.622171 [/Devices/ahci/0/LUN#999/Config/] (level 5)
00:00:00.622172   DeviceInstance       <string>  = "ahci/0" (cb=7)
00:00:00.622172   First                <integer> = 0x0000000000000000 (0)
00:00:00.622172   HasMediumAttachments <integer> = 0x0000000000000001 (1)
00:00:00.622173   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622173   iLedSet              <integer> = 0x0000000000000004 (4)
00:00:00.622173
00:00:00.622173 [/Devices/apic/] (level 2)
00:00:00.622174
00:00:00.622174 [/Devices/apic/0/] (level 3)
00:00:00.622174   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622174
00:00:00.622174 [/Devices/apic/0/Config/] (level 4)
00:00:00.622175   IOAPIC  <integer> = 0x0000000000000001 (1)
00:00:00.622175   Mode    <integer> = 0x0000000000000003 (3)
00:00:00.622175   NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.622176
00:00:00.622176 [/Devices/dp8390/] (level 2)
00:00:00.622177
00:00:00.622177 [/Devices/e1000/] (level 2)
00:00:00.622177
00:00:00.622177 [/Devices/e1000/0/] (level 3)
00:00:00.622178   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622178   PCIDeviceNo   <integer> = 0x0000000000000003 (3)
00:00:00.622178   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622179   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622179
00:00:00.622179 [/Devices/e1000/0/Config/] (level 4)
00:00:00.622180   AdapterType    <integer> = 0x0000000000000000 (0)
00:00:00.622180   CableConnected <integer> = 0x0000000000000001 (1)
00:00:00.622180   LineSpeed      <integer> = 0x0000000000000000 (0)
00:00:00.622180   MAC            <bytes>   = "08 00 27 bc f8 fd" (cb=6)
00:00:00.622181
00:00:00.622181 [/Devices/e1000/0/LUN#0/] (level 4)
00:00:00.622181   Driver <string>  = "VMNet" (cb=6)
00:00:00.622182
00:00:00.622182 [/Devices/e1000/0/LUN#0/Config/] (level 5)
00:00:00.622182   Trunk     <string>  = "en0" (cb=4)
00:00:00.622182   TrunkType <integer> = 0x0000000000000003 (3)
00:00:00.622183
00:00:00.622183 [/Devices/e1000/0/LUN#999/] (level 4)
00:00:00.622183   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622184
00:00:00.622184 [/Devices/e1000/0/LUN#999/Config/] (level 5)
00:00:00.622184   First                <integer> = 0x0000000000000000 (0)
00:00:00.622184   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:00.622185   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622185   iLedSet              <integer> = 0x0000000000000005 (5)
00:00:00.622185
00:00:00.622185 [/Devices/efi/] (level 2)
00:00:00.622186
00:00:00.622186 [/Devices/efi/0/] (level 3)
00:00:00.622186   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622187
00:00:00.622187 [/Devices/efi/0/Config/] (level 4)
00:00:00.622187   64BitEntry  <integer> = 0x0000000000000001 (1)
00:00:00.622187   APIC        <integer> = 0x0000000000000001 (1)
00:00:00.622188   BootArgs    <string>  = "" (cb=1)
00:00:00.622188   DeviceProps <string>  = "" (cb=1)
00:00:00.622188   EfiRom      <string>  = "VBoxEFI64.fd" (cb=13)
00:00:00.622189   IOAPIC      <integer> = 0x0000000000000001 (1)
00:00:00.622189   McfgBase    <integer> = 0x0000000000000000 (0)
00:00:00.622189   McfgLength  <integer> = 0x0000000000000000 (0)
00:00:00.622189   NumCPUs     <integer> = 0x0000000000000001 (1)
00:00:00.622190   NvramFile   <string>  = "/Users/stephenchurchill/VirtualBox VMs/HA/HA.nvram" (cb=51)
00:00:00.622190   UUID        <bytes>   = "69 96 91 e9 9f e6 ef 40 91 dd 4a fa cc 83 52 ef" (cb=16)
00:00:00.622191   UuidLe      <integer> = 0x0000000000000001 (1)
00:00:00.622191
00:00:00.622191 [/Devices/efi/0/LUN#0/] (level 4)
00:00:00.622191   Driver <string>  = "NvramStore" (cb=11)
00:00:00.622192
00:00:00.622192 [/Devices/hda/] (level 2)
00:00:00.622192
00:00:00.622192 [/Devices/hda/0/] (level 3)
00:00:00.622192   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622193   PCIDeviceNo   <integer> = 0x0000000000000005 (5)
00:00:00.622193   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622193   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622193
00:00:00.622193 [/Devices/hda/0/AudioConfig/] (level 4)
00:00:00.622194
00:00:00.622194 [/Devices/hda/0/Config/] (level 4)
00:00:00.622194   DebugEnabled <integer> = 0x0000000000000000 (0)
00:00:00.622195
00:00:00.622195 [/Devices/hda/0/LUN#0/] (level 4)
00:00:00.622195   Driver <string>  = "AUDIO" (cb=6)
00:00:00.622195
00:00:00.622195 [/Devices/hda/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.622196   Driver <string>  = "CoreAudio" (cb=10)
00:00:00.622196
00:00:00.622196 [/Devices/hda/0/LUN#0/AttachedDriver/Config/] (level 6)
00:00:00.622197
00:00:00.622197 [/Devices/hda/0/LUN#0/Config/] (level 5)
00:00:00.622197   DriverName    <string>  = "CoreAudio" (cb=10)
00:00:00.622198   InputEnabled  <integer> = 0x0000000000000000 (0)
00:00:00.622198   OutputEnabled <integer> = 0x0000000000000001 (1)
00:00:00.622198
00:00:00.622198 [/Devices/hda/0/LUN#1/] (level 4)
00:00:00.622199   Driver <string>  = "AUDIO" (cb=6)
00:00:00.622199
00:00:00.622199 [/Devices/hda/0/LUN#2/] (level 4)
00:00:00.622199
00:00:00.622200 [/Devices/i8254/] (level 2)
00:00:00.622200
00:00:00.622200 [/Devices/i8254/0/] (level 3)
00:00:00.622200
00:00:00.622200 [/Devices/i8254/0/Config/] (level 4)
00:00:00.622201
00:00:00.622201 [/Devices/i8259/] (level 2)
00:00:00.622201
00:00:00.622201 [/Devices/i8259/0/] (level 3)
00:00:00.622202   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622202
00:00:00.622202 [/Devices/i8259/0/Config/] (level 4)
00:00:00.622202
00:00:00.622202 [/Devices/ioapic/] (level 2)
00:00:00.622203
00:00:00.622203 [/Devices/ioapic/0/] (level 3)
00:00:00.622203   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622203
00:00:00.622203 [/Devices/ioapic/0/Config/] (level 4)
00:00:00.622204   NumCPUs <integer> = 0x0000000000000001 (1)
00:00:00.622204
00:00:00.622204 [/Devices/mc146818/] (level 2)
00:00:00.622204
00:00:00.622204 [/Devices/mc146818/0/] (level 3)
00:00:00.622205
00:00:00.622205 [/Devices/mc146818/0/Config/] (level 4)
00:00:00.622205   UseUTC <integer> = 0x0000000000000001 (1)
00:00:00.622205
00:00:00.622206 [/Devices/parallel/] (level 2)
00:00:00.622206
00:00:00.622206 [/Devices/pcarch/] (level 2)
00:00:00.622206
00:00:00.622206 [/Devices/pcarch/0/] (level 3)
00:00:00.622207   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622207
00:00:00.622207 [/Devices/pcarch/0/Config/] (level 4)
00:00:00.622207
00:00:00.622207 [/Devices/pci/] (level 2)
00:00:00.622208
00:00:00.622208 [/Devices/pci/0/] (level 3)
00:00:00.622208   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622208
00:00:00.622208 [/Devices/pci/0/Config/] (level 4)
00:00:00.622209   IOAPIC <integer> = 0x0000000000000001 (1)
00:00:00.622209
00:00:00.622209 [/Devices/pcibridge/] (level 2)
00:00:00.622209
00:00:00.622209 [/Devices/pckbd/] (level 2)
00:00:00.622210
00:00:00.622210 [/Devices/pckbd/0/] (level 3)
00:00:00.622210   Trusted <integer> = 0x0000000000000001 (1)
00:00:00.622210
00:00:00.622210 [/Devices/pckbd/0/Config/] (level 4)
00:00:00.622211
00:00:00.622211 [/Devices/pckbd/0/LUN#0/] (level 4)
00:00:00.622211   Driver <string>  = "KeyboardQueue" (cb=14)
00:00:00.622211
00:00:00.622211 [/Devices/pckbd/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.622212   Driver <string>  = "MainKeyboard" (cb=13)
00:00:00.622212
00:00:00.622212 [/Devices/pckbd/0/LUN#0/Config/] (level 5)
00:00:00.622213   QueueSize <integer> = 0x0000000000000040 (64, 64 B)
00:00:00.622213
00:00:00.622213 [/Devices/pckbd/0/LUN#1/] (level 4)
00:00:00.622213   Driver <string>  = "MouseQueue" (cb=11)
00:00:00.622214
00:00:00.622214 [/Devices/pckbd/0/LUN#1/AttachedDriver/] (level 5)
00:00:00.622214   Driver <string>  = "MainMouse" (cb=10)
00:00:00.622214
00:00:00.622214 [/Devices/pckbd/0/LUN#1/Config/] (level 5)
00:00:00.622215   QueueSize <integer> = 0x0000000000000080 (128, 128 B)
00:00:00.622215
00:00:00.622215 [/Devices/pcnet/] (level 2)
00:00:00.622216
00:00:00.622216 [/Devices/piix3ide/] (level 2)
00:00:00.622216
00:00:00.622216 [/Devices/piix3ide/0/] (level 3)
00:00:00.622216   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622217   PCIDeviceNo   <integer> = 0x0000000000000001 (1)
00:00:00.622217   PCIFunctionNo <integer> = 0x0000000000000001 (1)
00:00:00.622217   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622217
00:00:00.622218 [/Devices/piix3ide/0/Config/] (level 4)
00:00:00.622218   Type <string>  = "PIIX4" (cb=6)
00:00:00.622218
00:00:00.622218 [/Devices/piix3ide/0/LUN#2/] (level 4)
00:00:00.622219   Driver <string>  = "VD" (cb=3)
00:00:00.622219
00:00:00.622219 [/Devices/piix3ide/0/LUN#2/Config/] (level 5)
00:00:00.622219   EmptyDrive <integer> = 0x0000000000000001 (1)
00:00:00.622220   Mountable  <integer> = 0x0000000000000001 (1)
00:00:00.622220   Type       <string>  = "DVD" (cb=4)
00:00:00.622220
00:00:00.622220 [/Devices/piix3ide/0/LUN#999/] (level 4)
00:00:00.622221   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622221
00:00:00.622221 [/Devices/piix3ide/0/LUN#999/Config/] (level 5)
00:00:00.622221   DeviceInstance       <string>  = "piix3ide/0" (cb=11)
00:00:00.622222   First                <integer> = 0x0000000000000000 (0)
00:00:00.622222   HasMediumAttachments <integer> = 0x0000000000000001 (1)
00:00:00.622222   Last                 <integer> = 0x0000000000000003 (3)
00:00:00.622223   iLedSet              <integer> = 0x0000000000000003 (3)
00:00:00.622223
00:00:00.622223 [/Devices/serial/] (level 2)
00:00:00.622223
00:00:00.622223 [/Devices/usb-ehci/] (level 2)
00:00:00.622224
00:00:00.622224 [/Devices/usb-ehci/0/] (level 3)
00:00:00.622224   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622224   PCIDeviceNo   <integer> = 0x000000000000000b (11)
00:00:00.622225   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622225   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622225
00:00:00.622225 [/Devices/usb-ehci/0/Config/] (level 4)
00:00:00.622225
00:00:00.622226 [/Devices/usb-ehci/0/LUN#0/] (level 4)
00:00:00.622226   Driver <string>  = "VUSBRootHub" (cb=12)
00:00:00.622226
00:00:00.622226 [/Devices/usb-ehci/0/LUN#0/Config/] (level 5)
00:00:00.622227
00:00:00.622227 [/Devices/usb-ehci/0/LUN#999/] (level 4)
00:00:00.622227   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622227
00:00:00.622227 [/Devices/usb-ehci/0/LUN#999/Config/] (level 5)
00:00:00.622228   First                <integer> = 0x0000000000000000 (0)
00:00:00.622228   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:00.622228   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622229   iLedSet              <integer> = 0x0000000000000002 (2)
00:00:00.622229
00:00:00.622229 [/Devices/usb-ohci/] (level 2)
00:00:00.622229
00:00:00.622229 [/Devices/usb-ohci/0/] (level 3)
00:00:00.622230   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622230   PCIDeviceNo   <integer> = 0x0000000000000006 (6)
00:00:00.622231   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622231   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622231
00:00:00.622231 [/Devices/usb-ohci/0/Config/] (level 4)
00:00:00.622231
00:00:00.622232 [/Devices/usb-ohci/0/LUN#0/] (level 4)
00:00:00.622232   Driver <string>  = "VUSBRootHub" (cb=12)
00:00:00.622232
00:00:00.622232 [/Devices/usb-ohci/0/LUN#0/Config/] (level 5)
00:00:00.622233
00:00:00.622233 [/Devices/usb-ohci/0/LUN#999/] (level 4)
00:00:00.622233   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622233
00:00:00.622233 [/Devices/usb-ohci/0/LUN#999/Config/] (level 5)
00:00:00.622234   First                <integer> = 0x0000000000000000 (0)
00:00:00.622234   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:00.622234   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622235   iLedSet              <integer> = 0x0000000000000001 (1)
00:00:00.622235
00:00:00.622235 [/Devices/vga/] (level 2)
00:00:00.622235
00:00:00.622235 [/Devices/vga/0/] (level 3)
00:00:00.622236   PCIBusNo      <integer> = 0x0000000000000000 (0)
00:00:00.622236   PCIDeviceNo   <integer> = 0x0000000000000002 (2)
00:00:00.622236   PCIFunctionNo <integer> = 0x0000000000000000 (0)
00:00:00.622236   Trusted       <integer> = 0x0000000000000001 (1)
00:00:00.622237
00:00:00.622237 [/Devices/vga/0/Config/] (level 4)
00:00:00.622237   3DEnabled          <integer> = 0x0000000000000000 (0)
00:00:00.622238   CustomVideoModes   <integer> = 0x0000000000000000 (0)
00:00:00.622238   FadeIn             <integer> = 0x0000000000000001 (1)
00:00:00.622238   FadeOut            <integer> = 0x0000000000000001 (1)
00:00:00.622239   HeightReduction    <integer> = 0x0000000000000000 (0)
00:00:00.622239   LogoFile           <string>  = "" (cb=1)
00:00:00.622239   LogoTime           <integer> = 0x0000000000000000 (0)
00:00:00.622239   MonitorCount       <integer> = 0x0000000000000001 (1)
00:00:00.622240   ShowBootMenu       <integer> = 0x0000000000000002 (2)
00:00:00.622240   VMSVGA3dEnabled    <integer> = 0x0000000000000000 (0)
00:00:00.622240   VMSVGAEnabled      <integer> = 0x0000000000000001 (1)
00:00:00.622240   VMSVGAPciBarLayout <integer> = 0x0000000000000001 (1)
00:00:00.622241   VMSVGAPciId        <integer> = 0x0000000000000001 (1)
00:00:00.622241   VRamSize           <integer> = 0x0000000001000000 (16 777 216, 16.0 MiB)
00:00:00.622242
00:00:00.622242 [/Devices/vga/0/LUN#0/] (level 4)
00:00:00.622242   Driver <string>  = "MainDisplay" (cb=12)
00:00:00.622242
00:00:00.622242 [/Devices/vga/0/LUN#0/Config/] (level 5)
00:00:00.622243
00:00:00.622243 [/Devices/vga/0/LUN#999/] (level 4)
00:00:00.622243   Driver <string>  = "MainStatus" (cb=11)
00:00:00.622243
00:00:00.622243 [/Devices/vga/0/LUN#999/Config/] (level 5)
00:00:00.622244   First                <integer> = 0x0000000000000000 (0)
00:00:00.622244   HasMediumAttachments <integer> = 0x0000000000000000 (0)
00:00:00.622245   Last                 <integer> = 0x0000000000000000 (0)
00:00:00.622245   iLedSet              <integer> = 0x0000000000000000 (0)
00:00:00.622245
00:00:00.622245 [/Devices/virtio-net/] (level 2)
00:00:00.622246
00:00:00.622246 [/EM/] (level 1)
00:00:00.622246   TripleFaultReset <integer> = 0x0000000000000000 (0)
00:00:00.622246
00:00:00.622246 [/GCM/] (level 1)
00:00:00.622247   FixerSet <integer> = 0x0000000000000000 (0)
00:00:00.622247
00:00:00.622247 [/GIM/] (level 1)
00:00:00.622247   Provider <string>  = "KVM" (cb=4)
00:00:00.622247
00:00:00.622247 [/HM/] (level 1)
00:00:00.622248   64bitEnabled            <integer> = 0x0000000000000001 (1)
00:00:00.622248   EnableLargePages        <integer> = 0x0000000000000001 (1)
00:00:00.622248   EnableNestedPaging      <integer> = 0x0000000000000001 (1)
00:00:00.622249   EnableUX                <integer> = 0x0000000000000001 (1)
00:00:00.622249   EnableVPID              <integer> = 0x0000000000000001 (1)
00:00:00.622249   Exclusive               <integer> = 0x0000000000000000 (0)
00:00:00.622250   HMForced                <integer> = 0x0000000000000001 (1)
00:00:00.622250   IBPBOnVMEntry           <integer> = 0x0000000000000000 (0)
00:00:00.622250   IBPBOnVMExit            <integer> = 0x0000000000000000 (0)
00:00:00.622251   L1DFlushOnSched         <integer> = 0x0000000000000001 (1)
00:00:00.622251   L1DFlushOnVMEntry       <integer> = 0x0000000000000000 (0)
00:00:00.622251   LovelyMesaDrvWorkaround <integer> = 0x0000000000000001 (1)
00:00:00.622251   MDSClearOnSched         <integer> = 0x0000000000000001 (1)
00:00:00.622252   MDSClearOnVMEntry       <integer> = 0x0000000000000000 (0)
00:00:00.622252   SpecCtrlByHost          <integer> = 0x0000000000000000 (0)
00:00:00.622252   SvmVirtVmsaveVmload     <integer> = 0x0000000000000000 (0)
00:00:00.622253   UseNEMInstead           <integer> = 0x0000000000000000 (0)
00:00:00.622253
00:00:00.622253 [/MM/] (level 1)
00:00:00.622253   CanUseLargerHeap <integer> = 0x0000000000000000 (0)
00:00:00.622253
00:00:00.622254 [/NEM/] (level 1)
00:00:00.622254   Allow64BitGuests        <integer> = 0x0000000000000001 (1)
00:00:00.622254   LovelyMesaDrvWorkaround <integer> = 0x0000000000000001 (1)
00:00:00.622254
00:00:00.622254 [/PDM/] (level 1)
00:00:00.622255
00:00:00.622255 [/PDM/AsyncCompletion/] (level 2)
00:00:00.622255
00:00:00.622255 [/PDM/AsyncCompletion/File/] (level 3)
00:00:00.622255
00:00:00.622256 [/PDM/AsyncCompletion/File/BwGroups/] (level 4)
00:00:00.622256
00:00:00.622256 [/PDM/BlkCache/] (level 2)
00:00:00.622256   CacheSize <integer> = 0x0000000000500000 (5 242 880, 5.0 MiB)
00:00:00.622257
00:00:00.622257 [/PDM/Devices/] (level 2)
00:00:00.622257
00:00:00.622257 [/PDM/Devices/VBoxNvme/] (level 3)
00:00:00.622258   Path <string>  = "/Applications/VirtualBox.app/Contents/MacOS/ExtensionPacks/Oracle_VM_VirtualBox_Extension_Pack/darwin.arm64/VBoxNvmeR3.dylib" (cb=125)
00:00:00.622258
00:00:00.622258 [/PDM/Drivers/] (level 2)
00:00:00.622258
00:00:00.622258 [/PDM/Drivers/VBoxC/] (level 3)
00:00:00.622259   Path <string>  = "/Applications/VirtualBox.app/Contents/MacOS/components/VBoxC" (cb=61)
00:00:00.622259
00:00:00.622259 [/PDM/NetworkShaper/] (level 2)
00:00:00.622259
00:00:00.622259 [/PDM/NetworkShaper/BwGroups/] (level 3)
00:00:00.622261
00:00:00.622261 [/PDM/USB/] (level 2)
00:00:00.622261
00:00:00.622261 [/PDM/USB/VBoxUsbCardReader/] (level 3)
00:00:00.622261   Path <string>  = "/Applications/VirtualBox.app/Contents/MacOS/ExtensionPacks/Oracle_VM_VirtualBox_Extension_Pack/darwin.arm64/VBoxUsbCardReaderR3.dylib" (cb=134)
00:00:00.622262
00:00:00.622262 [/PDM/USB/VBoxUsbWebcam/] (level 3)
00:00:00.622262   Path <string>  = "/Applications/VirtualBox.app/Contents/MacOS/ExtensionPacks/Oracle_VM_VirtualBox_Extension_Pack/darwin.arm64/VBoxUsbWebcamR3.dylib" (cb=130)
00:00:00.622262
00:00:00.622262 [/TM/] (level 1)
00:00:00.622263   UTCOffset <integer> = 0x0000000000000000 (0)
00:00:00.622263
00:00:00.622263 [/USB/] (level 1)
00:00:00.622263
00:00:00.622263 [/USB/HidMouse/] (level 2)
00:00:00.622264
00:00:00.622264 [/USB/HidMouse/0/] (level 3)
00:00:00.622264
00:00:00.622264 [/USB/HidMouse/0/Config/] (level 4)
00:00:00.622264   Mode <string>  = "absolute" (cb=9)
00:00:00.622265
00:00:00.622265 [/USB/HidMouse/0/LUN#0/] (level 4)
00:00:00.622265   Driver <string>  = "MouseQueue" (cb=11)
00:00:00.622265
00:00:00.622265 [/USB/HidMouse/0/LUN#0/AttachedDriver/] (level 5)
00:00:00.622266   Driver <string>  = "MainMouse" (cb=10)
00:00:00.622266
00:00:00.622266 [/USB/HidMouse/0/LUN#0/Config/] (level 5)
00:00:00.622266   QueueSize <integer> = 0x0000000000000080 (128, 128 B)
00:00:00.622267
00:00:00.622267 [/USB/USBProxy/] (level 2)
00:00:00.622267
00:00:00.622267 [/USB/USBProxy/GlobalConfig/] (level 3)
00:00:00.622268
00:00:00.622268 ********************* End of CFGM dump **********************
It seems like Home Assistant doesn’t work with the latest version of Virtual Box. I downgraded to 6.1.42 and everything started working again.
