Crash while using google maps
I’m experiencing several crashes since last update (at least it didn’t happen before) while using oogle maps. Everytime I’m navigating, a window saying Home Assistant doesn’t answer appears several times which is very annoying while navigating.
According to the report this is the error:
Caused by:
"ANR Broadcast of Intent {act=io.homeassistant.companion.android.background.UPDATE_ACTIVITY flg=0xq0 cmp=io.homeassistant.companion.android/.sensors.ActivitySensorManager (has extras) }
Any easy way to fix this? Thanks!
Looks like an issue with the Activity Detection sensor, you can disable that to get rid of the error. There is probably another traceback above or below this to tell us what the actual failure is. Hard to tell but this sensor is dependent on google services so if you had a custom ROM then that may be a culprit too.
