Crashed the system, any help appreciated
im running node-red as a home assistant addon and was playing around downloading ble palettes when i crashed the system. Any and all help is welcome
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
 Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 17.0.3
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.4  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2024.1.6
 Home Assistant Supervisor: 2023.12.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
npm WARN deprecated @npmcli/[email protected]: This functionality has been moved to @npmcli/fs
up to date, audited 460 packages in 15s
44 packages are looking for funding
  run `npm fund` for details
25 vulnerabilities (12 moderate, 13 high)
To address issues that do not require attention, run:
  npm audit fix
To address all issues possible (including breaking changes), run:
  npm audit fix --force
Some issues need review, and may require choosing
a different dependency.
Run `npm audit` for details.
npm notice
npm notice New minor version of npm available! 10.2.3 -> 10.4.0
npm notice Changelog: <https://github.com/npm/cli/releases/tag/v10.4.0>
npm notice Run `npm install -g [email protected]` to update!
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[10:51:06] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
31 Jan 16:51:10 - [info]
Welcome to Node-RED
31 Jan 16:51:10 - [info] Node-RED version: v3.1.3
31 Jan 16:51:10 - [info] Node.js  version: v18.19.0
31 Jan 16:51:10 - [info] Linux 6.1.63-haos-raspi arm64 LE
31 Jan 16:51:12 - [info] Loading palette nodes
31 Jan 16:51:13 - [info] Node-RED Contrib Theme Collection version: v3.1.8
31 Jan 16:51:19 - [info] Dashboard version 3.6.2 started at /endpoint/ui
31 Jan 16:51:21 - [warn] ------------------------------------------------------
31 Jan 16:51:21 - [warn] [node-red-contrib-noble/noble] Error: Cannot find module '../build/Release/binding.node'
Require stack:
- /config/node_modules/bluetooth-hci-socket/lib/native.js
- /config/node_modules/bluetooth-hci-socket/index.js
- /config/node_modules/noble/lib/hci-socket/hci.js
- /config/node_modules/noble/lib/hci-socket/bindings.js
- /config/node_modules/noble/lib/resolve-bindings.js
- /config/node_modules/noble/index.js
- /config/node_modules/node-red-contrib-ignoble/ignoble-node.js
- /opt/node_modules/@node-red/registry/lib/loader.js
- /opt/node_modules/@node-red/registry/lib/index.js
- /opt/node_modules/@node-red/runtime/lib/nodes/index.js
- /opt/node_modules/@node-red/runtime/lib/index.js
- /opt/node_modules/node-red/lib/red.js
- /opt/node_modules/node-red/red.js
31 Jan 16:51:21 - [warn] [node-red-contrib-ignoble/noble] Error: Cannot find module '../build/Release/binding.node'
Require stack:
31 Jan 16:51:21 - [warn] [node-red-contrib-ble/uartBLE] Error: Cannot find module '../build/Release/binding.node'
Require stack:
- /config/node_modules/noble-device/node_modules/noble/lib/hci-socket/hci.js
- /config/node_modules/noble-device/node_modules/noble/lib/hci-socket/bindings.js
- /config/node_modules/noble-device/node_modules/noble/lib/noble.js
- /config/node_modules/noble-device/node_modules/noble/index.js
- /config/node_modules/noble-device/lib/util.js
- /config/node_modules/noble-device/index.js
- /config/node_modules/node-uartble/lib/uartble.js
- /config/node_modules/node-uartble/index.js
- /config/node_modules/node-red-contrib-ble/uartble/node-red-uartble.js
31 Jan 16:51:21 - [info] Settings file  : /etc/node-red/config.js
31 Jan 16:51:21 - [info] Context store  : 'default' [module=memory]
31 Jan 16:51:21 - [info] User directory : /config/
31 Jan 16:51:21 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Jan 16:51:21 - [info] Flows file     : /config/flows.json
31 Jan 16:51:21 - [info] Server now running at http://127.0.0.1:46836/
Your flow credentials file is encrypted using a system-generated key.
If the system-generated key is lost for any reason, your credentials
file will not be recoverable, you will have to delete it and re-enter
your credentials.
You should set your own key using the 'credentialSecret' option in
your settings file. Node-RED will then re-encrypt your credentials
file using your chosen key the next time you deploy a change.
31 Jan 16:51:21 - [info] [GenericBLE] Start BLE scanning
31 Jan 16:51:21 - [info] Starting flows
[10:51:21] INFO: Starting NGinx...
31 Jan 16:51:21 - [error] [pythonshell in:e0f9f4f63e19d55f] configured virtualenv not exist, consider remove or change
31 Jan 16:51:22 - [info] [GenericBLE] Start BLE scanning
31 Jan 16:51:22 - [info] Started flows
31 Jan 16:51:22 - [info] [server:Home Assistant] Connecting to http://supervisor/core
31 Jan 16:51:22 - [info] [server:Home Assistant] Connected to http://supervisor/core
on -> stateChange: poweredOn
on -> advertisingStart: success
31 Jan 16:51:26 - [info] [server:Home Assistant] Connecting to http://supervisor/core
31 Jan 16:51:26 - [info] [server:Home Assistant] Connected to http://supervisor/core
On the configuration page of the addon turn on safe mode save and restart. It should start and then remove problem nodes from palette.
no luck
 Add-on: Node-RED
Log level is set to TRACE
[11:27:14] TRACE: bashio::config.has_value: system_packages
[11:27:14] TRACE: bashio::addon.ip_address
[11:27:14] TRACE: bashio::addons self addons.self.ip_address .ip_address // empty
[11:27:14] TRACE: bashio::config: system_packages
[11:27:14] TRACE: bashio::cache.exists: addons.self.ip_address
[11:27:14] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.ip_address.cache
[11:27:14] TRACE: bashio::addon.config
[11:27:14] TRACE: bashio::var.false: self
[11:27:14] TRACE: bashio::cache.exists: addons.self.options.config
[11:27:14] TRACE: bashio::cache.exists: addons.self.info
[11:27:14] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache
[11:27:14] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.info.cache
[11:27:14] TRACE: bashio::cache.get: addons.self.options.config
[11:27:14] TRACE: bashio::cache.get: addons.self.info
[11:27:14] TRACE: bashio::var.has_value: .ip_address // empty
[11:27:14] TRACE: bashio::jq: {"theme":"default","http_node":{"username":"","password":""},"http_static":{"username":"","password":""},"ssl":false,"certfile":"fullchain.pem","keyfile":"privkey.pem","system_packages":["make","expect","g++","python3"],"npm_packages":["serialport","bindings"],"init_commands":[],"log_level":"trace","safe_mode":true,"leave_front_door_open":true} if (.system_packages == null) then
            null
        elif (.system_packages | type == "string") then
            .system_packages // empty
        elif (.system_packages | type == "boolean") then
            .system_packages // false
        elif (.system_packages | type == "array") then
            if (.system_packages == []) then
                empty
            else
                .system_packages[]
            end
        elif (.system_packages | type == "object") then
            if (.system_packages == {}) then
                empty
            else
                .system_packages
            end
        else
            .system_packages
        end
[11:27:14] TRACE: bashio::jq: {"name":"Node-RED","slug":"a0d7b954_nodered","hostname":"a0d7b954-nodered","dns":["a0d7b954-nodered.local.hass.io"],"description":"Flow-based programming for the Internet of Things","long_description":"# Home Assistant Community Add-on: Node-RED
[![Release][release-shield]][release] ![Project Stage][project-stage-shield] ![Project Maintenance][maintenance-shield]
[![Discord][discord-shield]][discord] [![Community Forum][forum-shield]][forum]
[![Sponsor Frenck via GitHub Sponsors][github-sponsors-shield]][github-sponsors]
[![Support Frenck on Patreon][patreon-shield]][patreon]
Flow-based programming for the Internet of Things.
## About
[Node-RED][nodered] is a programming tool for wiring together hardware devices,
APIs and online services in new and interesting ways.
It provides a browser-based editor that makes it easy to wire together flows
using the wide range of nodes in the palette that can be deployed to its
runtime in a single click.
![Node-RED in the Home Assistant Frontend][screenshot]
[discord-shield]: https://img.shields.io/discord/478094546522079232.svg
[discord]: https://discord.me/hassioaddons
[forum-shield]: https://img.shields.io/badge/community-forum-brightgreen.svg
[forum]: https://community.home-assistant.io/t/home-assistant-community-add-on-node-red/55023?u=frenck
[github-sponsors-shield]: https://frenck.dev/wp-content/uploads/2019/12/github_sponsor.png
[github-sponsors]: https://github.com/sponsors/frenck
[maintenance-shield]: https://img.shields.io/maintenance/yes/2024.svg
[nodered]: https://nodered.org
[patreon-shield]: https://frenck.dev/wp-content/uploads/2019/12/patreon.png
[patreon]: https://www.patreon.com/frenck
[project-stage-shield]: https://img.shields.io/badge/project%20stage-production%20ready-brightgreen.svg
[release-shield]: https://img.shields.io/badge/version-v17.0.3-blue.svg
[release]: https://github.com/hassio-addons/addon-node-red/tree/v17.0.3
[screenshot]: https://github.com/hassio-addons/addon-node-red/raw/main/images/screenshot.png","advanced":false,"stage":"stable","repository":"a0d7b954","version_latest":"17.0.3","protected":true,"rating":6,"boot":"auto","options":{"theme":"default","http_node":{"username":"","password":""},"http_static":{"username":"","password":""},"ssl":false,"certfile":"fullchain.pem","keyfile":"privkey.pem","system_packages":["make","expect","g++","python3"],"npm_packages":["serialport","bindings"],"init_commands":[],"log_level":"trace","safe_mode":true,"leave_front_door_open":true},"schema":[{"name":"log_level","optional":true,"type":"select","options":["trace","debug","info","notice","warning","error","fatal"]},{"name":"credential_secret","optional":true,"type":"string","format":"password"},{"name":"theme","optional":true,"type":"select","options":["default","aurora","cobalt2","dark","dracula","espresso-libre","github-dark","github-dark-default","github-dark-dimmed","midnight-red","monoindustrial","monokai","monokai-dimmed","noctis","oceanic-next","oled","one-dark-pro","one-dark-pro-darker","solarized-dark","solarized-light","tokyo-night","tokyo-night-light","tokyo-night-storm","totallyinformation","zenburn"]},{"name":"http_node","type":"schema","optional":true,"multiple":false,"schema":[{"name":"username","required":true,"type":"string"},{"name":"password","required":true,"type":"string","format":"password"}]},{"name":"http_static","type":"schema","optional":true,"multiple":false,"schema":[{"name":"username","required":true,"type":"string"},{"name":"password","required":true,"type":"string","format":"password"}]},{"name":"ssl","required":true,"type":"boolean"},{"name":"certfile","required":true,"type":"string"},{"name":"keyfile","required":true,"type":"string"},{"name":"system_packages","multiple":true,"required":true,"type":"string"},{"name":"npm_packages","multiple":true,"required":true,"type":"string"},{"name":"init_commands","multiple":true,"required":true,"type":"string"},{"name":"leave_front_door_open","optional":true,"type":"boolean"},{"name":"safe_mode","optional":true,"type":"boolean"},{"name":"max_old_space_size","optional":true,"type":"integer"}],"arch":["aarch64","amd64","armv7"],"machine":[],"homeassistant":"2023.3.0","url":"https://github.com/hassio-addons/addon-node-red","detached":false,"available":true,"build":false,"network":{"80/tcp":1880},"network_description":{"80/tcp":"Web interface"},"host_network":true,"host_pid":false,"host_ipc":false,"host_uts":false,"host_dbus":false,"privileged":[],"full_access":false,"apparmor":"default","icon":true,"logo":true,"changelog":true,"documentation":true,"stdin":false,"hassio_api":true,"hassio_role":"manager","auth_api":true,"homeassistant_api":true,"gpio":false,"usb":false,"uart":true,"kernel_modules":false,"devicetree":false,"udev":false,"docker_api":false,"video":false,"audio":false,"startup":"application","services":[],"discovery":[],"translations":{},"ingress":true,"signed":true,"state":"unknown","webui":null,"ingress_entry":"/api/hassio_ingress/uZn9kb9y3_sIz99pwC_g-y47KFtKEAaW2d9lgjnWoB0","ingress_url":"/api/hassio_ingress/uZn9kb9y3_sIz99pwC_g-y47KFtKEAaW2d9lgjnWoB0/","ingress_port":63136,"ingress_panel":false,"audio_input":null,"audio_output":null,"auto_update":false,"ip_address":"172.30.32.1","version":"17.0.3","update_available":false,"watchdog":false,"devices":[]} .ip_address // empty
Info
Documentation
Configuration
Log
Node-RED
Executing busybox-1.36.1-r15.trigger
OK: 68 MiB in 45 packages
(1/2) Installing tcl (8.6.13-r1)
(2/2) Installing expect (5.45.4-r4)
OK: 74 MiB in 47 packages
(1/14) Installing libstdc++-dev (13.2.1_git20231014-r0)
(2/14) Installing jansson (2.14-r4)
(3/14) Installing zstd-libs (1.5.5-r8)
(4/14) Installing binutils (2.41-r0)
(5/14) Installing libgomp (13.2.1_git20231014-r0)
(6/14) Installing libatomic (13.2.1_git20231014-r0)
(7/14) Installing gmp (6.3.0-r0)
(8/14) Installing isl26 (0.26-r1)
(9/14) Installing mpfr4 (4.2.1-r0)
(10/14) Installing mpc1 (1.3.1-r1)
(11/14) Installing gcc (13.2.1_git20231014-r0)
(12/14) Installing musl-dev (1.2.4_git20230717-r4)
(13/14) Installing libc-dev (0.7.2-r5)
(14/14) Installing g++ (13.2.1_git20231014-r0)
OK: 266 MiB in 61 packages
(1/11) Installing libbz2 (1.0.8-r6)
(2/11) Installing libffi (3.4.4-r3)
(3/11) Installing gdbm (1.23-r1)
(4/11) Installing xz-libs (5.4.5-r0)
(5/11) Installing mpdecimal (2.5.1-r2)
(6/11) Installing libpanelw (6.4_p20231125-r0)
(7/11) Installing sqlite-libs (3.44.2-r0)
(8/11) Installing python3 (3.11.6-r1)
(9/11) Installing python3-pycache-pyc0 (3.11.6-r1)
(10/11) Installing pyc (3.11.6-r1)
(11/11) Installing python3-pyc (3.11.6-r1)
OK: 310 MiB in 72 packages
[11:27:34] TRACE: bashio::config.has_value: npm_packages
[11:27:34] TRACE: bashio::config: npm_packages
[11:27:34] TRACE: bashio::addon.config
[11:27:34] TRACE: bashio::cache.exists: addons.self.options.config
[11:27:34] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache
[11:27:34] TRACE: bashio::cache.get: addons.self.options.config
[11:27:34] TRACE: bashio::jq: {"theme":"default","http_node":{"username":"","password":""},"http_static":{"username":"","password":""},"ssl":false,"certfile":"fullchain.pem","keyfile":"privkey.pem","system_packages":["make","expect","g++","python3"],"npm_packages":["serialport","bindings"],"init_commands":[],"log_level":"trace","safe_mode":true,"leave_front_door_open":true} if (.npm_packages == null) then
            null
        elif (.npm_packages | type == "string") then
            .npm_packages // empty
        elif (.npm_packages | type == "boolean") then
            .npm_packages // false
        elif (.npm_packages | type == "array") then
            if (.npm_packages == []) then
                empty
            else
                .npm_packages[]
            end
        elif (.npm_packages | type == "object") then
            if (.npm_packages == {}) then
                empty
            else
                .npm_packages
            end
        else
            .npm_packages
        end
[11:27:34] TRACE: bashio::var.has_value: serialport
bindings
[11:27:34] INFO: Starting installation of custom NPM/Node-RED packages...
            null
                empty
            else
                .npm_packages[]
            end
                empty
            else
                .npm_packages
            end
        else
            .npm_packages
        end
npm WARN config optional Use `--omit=optional` to exclude optional dependencies, or
npm WARN config `--include=optional` to include them.
npm WARN config
npm WARN config     Default value does install optional deps unless otherwise omitted.
npm WARN config only Use `--omit=dev` to omit dev dependencies from the install.
[11:28:36] TRACE: bashio::config: safe_mode
[11:28:36] TRACE: bashio::addon.config
[11:28:36] TRACE: bashio::cache.exists: addons.self.options.config
[11:28:36] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache
[11:28:36] TRACE: bashio::cache.get: addons.self.options.config
[11:28:37] TRACE: bashio::cache.exists: addons.self.options.config
[11:28:37] TRACE: bashio::fs.file_exists: /tmp/.bashio/addons.self.options.config.cache
[11:28:37] TRACE: bashio::jq: {"theme":"default","http_node":{"username":"","password":""},"http_static":{"username":"","password":""},"ssl":false,"certfile":"fullchain.pem","keyfile":"privkey.pem","system_packages":["make","expect","g++","python3"],"npm_packages":["serialport","bindings"],"init_commands":[],"log_level":"trace","safe_mode":true,"leave_front_door_open":true} if (.safe_mode == null) then
            null
        elif (.safe_mode | type == "string") then
            .safe_mode // empty
        elif (.safe_mode | type == "boolean") then
            .safe_mode // false
        elif (.safe_mode | type == "array") then
            if (.safe_mode == []) then
                empty
            else
                .safe_mode[]
            end
        elif (.safe_mode | type == "object") then
            if (.safe_mode == {}) then
                empty
            else
                .safe_mode
            end
        else
            .safe_mode
        end
[11:28:37] TRACE: bashio::var.true: true
[11:28:37] INFO: Setting safe mode startup
[11:28:37] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --safe --settings /etc/node-red/config.js
31 Jan 17:28:40 - [info]
Welcome to Node-RED
31 Jan 17:28:40 - [info] Node-RED version: v3.1.3
31 Jan 17:28:40 - [info] Node.js  version: v18.19.0
31 Jan 17:28:40 - [info] Linux 6.1.63-haos-raspi arm64 LE
31 Jan 17:28:42 - [info] Loading palette nodes
31 Jan 17:28:43 - [debug] Module: @cwe7976/node-red-contrib-easytouch-ble 1.0.3 /config/node_modules/@cwe7976/node-red-contrib-easytouch-ble
31 Jan 17:28:43 - [debug] Module: @edgewaretech/node-red-ble 0.0.5 /config/node_modules/@edgewaretech/node-red-ble
31 Jan 17:28:43 - [debug] Module: @hsync/node-red-ble-uart 0.4.0 /config/node_modules/@hsync/node-red-ble-uart
31 Jan 17:28:43 - [debug] Module: node-red-contrib-2jciebu-ble 0.0.3 /config/node_modules/node-red-contrib-2jciebu-ble
31 Jan 17:28:43 - [debug] Module: node-red-contrib-advlib-ble 0.0.4 /config/node_modules/node-red-contrib-advlib-ble
31 Jan 17:28:43 - [debug] Module: node-red-contrib-axios 1.2.0 /config/node_modules/node-red-contrib-axios
31 Jan 17:28:43 - [debug] Module: node-red-contrib-binary 0.1.3 /config/node_modules/node-red-contrib-binary
31 Jan 17:28:43 - [debug] Module: node-red-contrib-ble 0.0.2 /config/node_modules/node-red-contrib-ble
31 Jan 17:28:43 - [debug] Module: node-red-contrib-ble-scan 1.0.0 /config/node_modules/node-red-contrib-ble-scan
31 Jan 17:28:43 - [debug] Module: node-red-contrib-ble-sense 0.0.13 /config/node_modules/node-red-contrib-ble-sense
31 Jan 17:28:43 - [debug] Module: node-red-contrib-calc 1.0.5 /config/node_modules/node-red-contrib-calc
31 Jan 17:28:43 - [debug] Module: node-red-contrib-calculate 0.1.4 /config/node_modules/node-red-contrib-calculate
31 Jan 17:28:43 - [debug] Module: node-red-contrib-discovergy-meter 0.7.3 /config/node_modules/node-red-contrib-discovergy-meter
31 Jan 17:28:43 - [debug] Module: node-red-contrib-generic-ble-arcom 3.1.21 /config/node_modules/node-red-contrib-generic-ble-arcom
31 Jan 17:28:43 - [debug] Module: node-red-contrib-grove-base-hat-bash 1.1.4 /config/node_modules/node-red-contrib-grove-base-hat-bash
31 Jan 17:28:43 - [debug] Module: node-red-contrib-ignoble 0.0.12 /config/node_modules/node-red-contrib-ignoble
31 Jan 17:28:43 - [debug] Module: node-red-contrib-lescan 1.0.0-beta.1 /config/node_modules/node-red-contrib-lescan
31 Jan 17:28:43 - [debug] Module: node-red-contrib-mqtt-connection-check 0.1.2 /config/node_modules/node-red-contrib-mqtt-connection-check
31 Jan 17:28:43 - [debug] Module: node-red-contrib-ng 0.2.0 /config/node_modules/node-red-contrib-ng
31 Jan 17:28:43 - [debug] Module: node-red-contrib-noble 0.3.0 /config/node_modules/node-red-contrib-noble
31 Jan 17:28:43 - [debug] Module: node-red-contrib-noble-bluetooth 0.9.1 /config/node_modules/node-red-contrib-noble-bluetooth
31 Jan 17:28:43 - [debug] Module: node-red-contrib-pythonshell 1.5.4 /config/node_modules/node-red-contrib-pythonshell
31 Jan 17:28:43 - [debug] Module: node-red-contrib-shelly 10.13.3 /config/node_modules/node-red-contrib-shelly
31 Jan 17:28:43 - [debug] Module: node-red-contrib-tcp-client 0.1.3 /config/node_modules/node-red-contrib-tcp-client
31 Jan 17:28:43 - [debug] Module: node-red-contrib-tcp-server 0.1.0 /config/node_modules/node-red-contrib-tcp-server
31 Jan 17:28:43 - [debug] Module: node-red-contrib-time-of-day 0.0.4 /config/node_modules/node-red-contrib-time-of-day
31 Jan 17:28:43 - [debug] Module: node-red-contrib-timecheck 1.1.0 /config/node_modules/node-red-contrib-timecheck
31 Jan 17:28:43 - [debug] Module: node-red-contrib-webhookrelay 0.3.0 /config/node_modules/node-red-contrib-webhookrelay
31 Jan 17:28:43 - [debug] Module: node-red-contrib-websocket-auth0 0.1.2 /config/node_modules/node-red-contrib-websocket-auth0
31 Jan 17:28:43 - [debug] Module: node-red-contrib-wifiscan 0.0.2 /config/node_modules/node-red-contrib-wifiscan
31 Jan 17:28:43 - [debug] Module: node-red-contrib-xterm 1.0.1 /config/node_modules/node-red-contrib-xterm
31 Jan 17:28:43 - [debug] Module: node-red-node-serialport 2.0.2 /config/node_modules/node-red-node-serialport
31 Jan 17:28:43 - [debug] Module: node-red-rshake-udp-parser 0.0.10 /config/node_modules/node-red-rshake-udp-parser
31 Jan 17:28:43 - [debug] Module: @node-red-contrib-themes/theme-collection 3.1.8 /opt/node_modules/@node-red-contrib-themes/theme-collection
31 Jan 17:28:43 - [debug] Module: node-red-contrib-bigtimer 2.8.5 /opt/node_modules/node-red-contrib-bigtimer
31 Jan 17:28:43 - [debug] Module: node-red-contrib-cast 0.2.17 /opt/node_modules/node-red-contrib-cast
31 Jan 17:28:43 - [debug] Module: node-red-contrib-counter 0.1.6 /opt/node_modules/node-red-contrib-counter
31 Jan 17:28:43 - [debug] Module: node-red-contrib-home-assistant-websocket 0.62.3 /opt/node_modules/node-red-contrib-home-assistant-websocket
31 Jan 17:28:43 - [debug] Module: node-red-contrib-influxdb 0.7.0 /opt/node_modules/node-red-contrib-influxdb
31 Jan 17:28:43 - [debug] Module: node-red-contrib-interval-length 0.0.6 /opt/node_modules/node-red-contrib-interval-length
31 Jan 17:28:43 - [debug] Module: node-red-contrib-modbus 5.27.2 /opt/node_modules/node-red-contrib-modbus
31 Jan 17:28:43 - [debug] Module: node-red-contrib-moment 5.0.0 /opt/node_modules/node-red-contrib-moment
31 Jan 17:28:43 - [debug] Module: node-red-contrib-persistent-fsm 1.2.1 /opt/node_modules/node-red-contrib-persistent-fsm
31 Jan 17:28:43 - [debug] Module: node-red-contrib-sunevents 3.1.1 /opt/node_modules/node-red-contrib-sunevents
31 Jan 17:28:43 - [debug] Module: node-red-contrib-time-range-switch 1.2.0 /opt/node_modules/node-red-contrib-time-range-switch
31 Jan 17:28:43 - [debug] Module: node-red-dashboard 3.6.2 /opt/node_modules/node-red-dashboard
31 Jan 17:28:43 - [debug] Module: node-red-node-base64 0.3.0 /opt/node_modules/node-red-node-base64
31 Jan 17:28:43 - [debug] Module: node-red-node-email 2.1.0 /opt/node_modules/node-red-node-email
31 Jan 17:28:43 - [debug] Module: node-red-node-feedparser 0.3.0 /opt/node_modules/node-red-node-feedparser
31 Jan 17:28:43 - [debug] Module: node-red-node-ping 0.3.3 /opt/node_modules/node-red-node-ping
31 Jan 17:28:43 - [debug] Module: node-red-node-random 0.4.1 /opt/node_modules/node-red-node-random
31 Jan 17:28:43 - [debug] ! Module: node-red-node-serialport 2.0.2 /opt/node_modules/node-red-node-serialport *ignored due to local copy*
31 Jan 17:28:43 - [debug] Module: node-red-node-smooth 0.1.2 /opt/node_modules/node-red-node-smooth
31 Jan 17:28:43 - [debug] Module: node-red-node-suncalc 1.1.0 /opt/node_modules/node-red-node-suncalc
31 Jan 17:28:43 - [debug] Module: node-red-node-twitter 1.2.0 /opt/node_modules/node-red-node-twitter
31 Jan 17:28:43 - [info] Node-RED Contrib Theme Collection version: v3.1.8
31 Jan 17:28:49 - [info] Dashboard version 3.6.2 started at /endpoint/ui
31 Jan 17:28:51 - [warn] ------------------------------------------------------
31 Jan 17:28:51 - [warn] [node-red-contrib-noble/noble] Error: Cannot find module '../build/Release/binding.node'
Require stack:
31 Jan 17:28:51 - [warn] [node-red-contrib-ignoble/noble] Error: Cannot find module '../build/Release/binding.node'
Require stack:
31 Jan 17:28:51 - [warn] [node-red-contrib-ble/uartBLE] Error: Cannot find module '../build/Release/binding.node'
Require stack:
31 Jan 17:28:51 - [info] Settings file  : /etc/node-red/config.js
31 Jan 17:28:51 - [info] Context store  : 'default' [module=memory]
31 Jan 17:28:51 - [info] User directory : /config/
31 Jan 17:28:51 - [warn] Projects disabled : editorTheme.projects.enabled=false
31 Jan 17:28:51 - [info] Flows file     : /config/flows.json
31 Jan 17:28:51 - [info] Server now running at http://127.0.0.1:46836/
31 Jan 17:28:51 - [debug] loaded flow revision: 5d1ce152fd40bda36362120e1421d826
31 Jan 17:28:51 - [debug] red/runtime/nodes/credentials.load : no user key present
31 Jan 17:28:51 - [debug] red/runtime/nodes/credentials.load : using default key
31 Jan 17:28:51 - [debug] red/runtime/nodes/credentials.load : keyType=system
your credentials.
31 Jan 17:28:51 - [trace] runtime event: {"id":"runtime-state","retain":true}
31 Jan 17:28:51 - [info] [GenericBLE] Start BLE scanning
31 Jan 17:28:51 - [trace] runtime event: {"id":"runtime-deploy","payload":{"revision":"5d1ce152fd40bda36362120e1421d826"},"retain":true}
31 Jan 17:28:51 - [info] *****************************************************************
31 Jan 17:28:51 - [info] Flows stopped in safe mode. Deploy to start.
31 Jan 17:28:51 - [trace] runtime event: {"id":"runtime-state","payload":{"state":"safe","error":"safe-mode","type":"warning","text":"notification.warnings.safe-mode"},"retain":true}
[11:28:51] INFO: Starting NGinx...
theme: default
http_node:
  username: ""
  password: ""
http_static:
  username: ""
  password: ""
ssl: false
certfile: fullchain.pem
keyfile: privkey.pem
system_packages:
  - make
  - expect
  - g++
  - python3
npm_packages:
  - serialport
  - bindings
init_commands: []
log_level: trace
safe_mode: true
leave_front_door_open: true
I’m looking at both of your log dumps. Everything seems to be starting as expected. What is the actual problem?
You can’t open the nodered page? You have tried both the link from HA’s toolbar and using 1880 as the port number with ha’s network address?
yea it doesnt start and you cant login to node red using ip
shit im stoned it does work from the ip…thanks ill delete some palettes
Thank You!
is there a way to delete the flows home assistant has stored? i have them backed up on computer i just couldnt leave well enough alone and really buggered this thing all to hell now…
If you select the nodes, delete and then deploy, that’s it they’re gone.
it doesnt startup even in safe mode anymore id love to do it
You want to start fresh? You have deleted the addon? After deleting the addon go to config and rename the nodered folder to old_nodered.
Then one level up where your /media folder is. There is another nodred folder, rename that one as well. restart then reinstall
also had configs inside node red hanging onto the now missing nodes that needed to be deleted , thank you for your help
Once you are sure you have everything you need from your old setup, those folders can be deleted.
