I recently started using HA and for the last few days it has been crashing around once per day. Usually I will access the UI to do something so I know it works and when I access it again a minute or so later it has crashed so I don’t know if me accessing it is what is causing the crash. When It crashes I loose access to the UI, my automations stop working and it seems to get very hot but it does continue logging in the background until I restart the PI.
I have updated to the latest version but it was crashing on the previous version as well. It is running on a 2GB Raspberry PI 4 in an Argon One case with the official 15w power supply and an SSD. The only things I can remember changing since the crashes started is installing InfluxDB/Grafana and Zigbee2MQTT so it might be related to them.
I’ve attached the logs around the crash, the crash happened at around 1850 on the 4th.
2023-03-04 18:04:30.059 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grocy/stats request
2023-03-04 18:04:30.061 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_influxdb/stats request
2023-03-04 18:04:30.062 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2023-03-04 18:24:09.378 ERROR (MainThread) [homeassistant.components.steam_online] Error fetching steam_online data: Server took too long to respond
2023-03-04 18:30:12.048 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-03-04 18:30:13.681 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_influxdb/stats request
2023-03-04 18:30:13.685 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grafana/stats request
2023-03-04 18:30:13.688 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2023-03-04 18:30:13.691 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grocy/stats request
2023-03-04 18:30:13.693 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2023-03-04 18:30:13.696 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2023-03-04 18:40:32.047 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2023-03-04 18:50:51.047 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2023-03-04 18:50:51.957 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grafana/stats request
2023-03-04 18:50:51.960 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grocy/stats request
2023-03-04 18:50:51.963 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2023-03-04 18:50:51.967 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_influxdb/stats request
2023-03-04 18:50:51.970 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-03-04 18:50:51.974 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2023-03-04 18:56:32.454 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2023-03-04 19:00:04.521 ERROR (stream_worker) [homeassistant.components.stream.stream.camera.bird_camera_hd_stream] Error from stream worker: Error demuxing stream: [Errno 1414092869] Immediate exit requested: 'rtsp://TapoCameraAccount:[email protected]:554/stream1'
2023-03-04 19:01:18.862 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /ingress/session request
2023-03-04 19:01:19.467 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /ingress/session -
2023-03-04 19:01:19.471 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grafana/info request
2023-03-04 19:01:19.473 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_grafana/info -
2023-03-04 19:01:19.811 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.10/site-packages/aiohttp/http_websocket.py", line 676, in ping
await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.10/site-packages/aiohttp/http_websocket.py", line 653, in _send_frame
self._write(header + message)
File "/usr/local/lib/python3.10/site-packages/aiohttp/http_websocket.py", line 663, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2023-03-04 19:01:19.961 ERROR (MainThread) [roborock.api] Failed to subscribe (rc: 4)
2023-03-04 19:01:25.508 ERROR (MainThread) [homeassistant.components.yamaha_musiccast] Timeout fetching yamaha_musiccast data
2023-03-04 19:01:32.985 ERROR (MainThread) [roborock.api] Failed to subscribe (rc: 4)
2023-03-04 19:01:37.128 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/cebe7a76_hassio_google_drive_backup/stats request
2023-03-04 19:01:37.576 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mosquitto/stats request
2023-03-04 19:01:37.580 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/45df7312_zigbee2mqtt/stats request
2023-03-04 19:01:37.583 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grafana/stats request
2023-03-04 19:01:37.587 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_influxdb/stats request
2023-03-04 19:01:37.590 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_duckdns/stats request
2023-03-04 19:01:37.593 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_grocy/stats request
2023-03-04 19:01:37.596 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_nodered/stats request
2023-03-04 19:01:37.599 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_mariadb/stats request
2023-03-04 19:01:37.602 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_rpc_shutdown/stats request
2023-03-04 19:01:37.606 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_vscode/stats request
2023-03-04 19:01:37.609 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/7d06b5a0_argon_one_temp_linear/stats request
2023-03-04 19:01:37.613 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_adguard/stats request
2023-03-04 19:01:37.616 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/a0d7b954_ssh/stats request
2023-03-04 19:01:37.619 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_configurator/stats request
2023-03-04 19:01:37.622 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_samba/stats request
2023-03-04 19:02:49.758 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer
