Crazy Vu meter integrated to HA
With the help of this great community and also a lot of help from Wannaduino I’ve built two of his crazy vu meters.
So the VU Meter is this one: https://youtu.be/9un-IkhvpLI
It looks great.
To have it integrated into HA, I decided to go with this board
So with the help of a lot of guys here:
I got the relay board working, so the esphome config looks like this:
substitutions:
  device_name: vumeter1
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "WIFI_SSID"
  password: "WIFI_PASS"
# Enable Home Assistant API
api:
ota:
  password: "OTA_PASS"
# Enable logging
logger:
  baud_rate: 0 #need this to free up UART pins
uart:
  baud_rate: 115200 # speed to STC15L101EW
  tx_pin: GPIO1
  rx_pin: GPIO3
# Text Sensor with general information
text_sensor:
  - platform: version
    name: '${device_name} ESPHome Version'
  - platform: wifi_info
    ip_address:
    ssid:
  - platform: wifi_signal
    name: '${device_name} WiFi Signal'
    update_interval: 60s
    accuracy_decimals: 0
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
switch:
    turn_on_action:
      - uart.write: [0xA0, 0x01, 0x01, 0xA2]
    turn_off_action:
      - uart.write: [0xA0, 0x01, 0x00, 0xA1]
    optimistic: true
    name: '${device_name} Mode change'
    turn_on_action:
      - uart.write: [0xA0, 0x02, 0x01, 0xA3]
      - delay: 500ms
      - uart.write: [0xA0, 0x02, 0x00, 0xA2]
So relay1 handles the power-on/off, and the relay2 is set up as a momentary switch so it will change modes for the VU Meter.
I haven’t gotten the ‘foot’ 3dprinted yet, so I’ve just mounted it on a piece of pinewood. It looks like this:
The card I’ve made looks like this:
(here one is turned off, the other on).
The lovelace config looks like this:
cards:
  - color_type: blank-card
    type: 'custom:button-card'
  - cards:
      - type: picture-entity
        entity: switch.vumeter1_power
        show_name: false
        show_state: false
        state_image:
          'on': /local/vu-meter-on.png
          'off': /local/vu-meter-off.png
        tap_action:
          action: toggle
      - type: entity-button
        entity: switch.vumeter1_mode_change
        show_icon: false
    type: vertical-stack
  - cards:
        entity: switch.vumeter2_power
        show_name: false
        show_state: false
        state_image:
        tap_action:
          action: toggle
        entity: switch.vumeter2_mode_change
        show_icon: false
type: horizontal-stack
hi
your project looks realy good but i dont get your setup.
which code are you using for the LEDs?
I have built WannaDIY’s VU meters, you should be able to get the code from his website.
