Creality Integration
I’ve been on the lookout for a Creality resin Home Assistant integration but came up short in finding one. This led me to embark on creating my own integration, a first for me. Given that I’m not a developer and sought assistance from ChatGPT, you might notice this reflected in the code’s approach.
Despite these hurdles, I successfully developed an integration for my Creality Halot resin printer. I believe this might pique the interest of others, and I warmly invite contributions to improve and refine the code. The integration leverages WebSocket for communication, which I identified through Wireshark. However, I encountered difficulties in retrieving device info, resulting in the absence of details like the device’s software version and model number.
It’s important to note that I’ve only tested this integration with my Creality Halot resin printer. While it’s specifically tailored for this model, I speculate it could potentially work with any Creality printer that’s connected to a network.
For those intrigued or willing to contribute to this endeavor, the repository is accessible here: GitHub - Klangen82/Creality-Control: Seamlessly integrate your Creality 3D printer with Home Assistant for streamlined control and monitoring..
This project presents an opportunity for growth and improvement with community support. I’m enthusiastic about its potential and look forward to seeing how it evolves with your input!
Thanks for your post!
I found this when trying to find an integration for the Creality Wifi Box. I knew it was possible to get the status of the printer because both Cura and Creality slicer show it. Using Wireshark I was able to determine that all communication was done unauthenticated using http get. I don’t normally code in python, or make integrations, but using your code as a template I was able to get it working.
For fdm printer, try to use, no effect
Hey guys what is the password of Creality print. I don’t have it and I didn’t set a password
Does this work with the ender 3 v3 KE?
i need the same, for the K1C (non rooted)
Hey all, I’ve been working on integration using websockets for non-rooted Creality K-series printers. This is a first release and works on K1C. Looking for testers to verify on K1 and K2. Cheers!
This is really nice and works flawlessly with my K1C. Thanks for sharing!
PS.: is there anyway to deliver the estimated time in DD:hh:mm:ss format instead of raw seconds?!? It would be even nicer :slight_smile:
Hey! Thanks for using it. Please create issue in Github repo (otherwise I’ll forget), I’ll take a look next week. Please, mention also whether change requested is regarding card or integration.
This was great and easy to use. The only issue I have is the integration did not expose a temperature sensor for the Box. I am using a K1 Max
I updated the model detection logic and released a pre-release version of v0.6.3.6-alpha. You have to manually download it in HACS by going into three-dots-menu, pressing redownload and selecting this version
Perfect, Thanks!
Thanks for this! It works well on the new Creality Hi as well. Really appreciate your time, thanks
This integrations is great! works like a charm!
It works perfectly with my K1, thank you so much!
