I’m trying to make a 3 state sensor to describe humidity in words, such as “dry”, “comfortable” and " humid" which i can then use to show on the lovelace ui and also trigger automations more intuitivly.
is it possible?
thanks.
is it possible?
thanks.
You can use the text template sensor.
I started to type out an example on my phone but it started to get messy quickly
Success:
text_sensor:
name: ${devicename} Humidity Text
lambda: |-
if (id(living_room_humidity).state > 65) {
return {"Humid"};
} else if (id(living_room_humidity).state < 40) {
return {"Dry"};
} else {
return {"Comfortable"};
update_interval: 60s
took me a while to understand that it is just a plain c++ snippet.
Thanks for that. I was looking for Cardinal wind direction from a 0-360 degree wind direction signal.
The code below got it done for me, just in case someone needs it.
# Cardinal Wind direction
text_sensor:
name: Cardinal Wind Direction
lambda: |-
if (id(WindDir).state < 22.5 || id(WindDir).state >= 337.5) {
return {"North"};
} else if (id(WindDir).state >= 22.5 && id(WindDir).state < 67.5) {
return {"North East"};
} else if (id(WindDir).state >= 67.5 && id(WindDir).state < 112.5) {
return {"East"};
} else if (id(WindDir).state >= 112.5 && id(WindDir).state < 157.5) {
return {"South East"};
} else if (id(WindDir).state >= 157.5 && id(WindDir).state < 202.5) {
return {"South"};
} else if (id(WindDir).state >= 202.5 && id(WindDir).state < 247.5) {
return {"South West"};
} else if (id(WindDir).state >= 247.5 && id(WindDir).state < 292.5) {
return {"West"};
} else if (id(WindDir).state >= 292.5 && id(WindDir).state < 337.5) {
return {"North West"};
} else {
return {"Something is not Right..."};
update_interval: 1s
} else { return {"Something is not Right..."};
Great work!
huh?
maybe
} else return {"Something is not Right..."};
if it’s C++ code. Btw, do we need these {} around string here?
I unintentionally tested it. I accidentally used && for the north position.
It’s handy to keep in there for testing purposes.
I just like that you allowed for errors with a helpful message!
