I have the zwift integration which is working well for me but i want the attribute of FTP to show as a sensor that i can use in nodered
i have the attribute in lovelace using this
thanks for your help i’m interested in trying the new config, if i’m using a sensor folder" /config/sensor.yaml " and i already have other templates and sensors.
should i format your suggestion differently as i’m getting error when checking the config
“end of the stream or a document separator is expected at line 39, column 1:
template:
or if i remove the template line i get
“Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 23).”
