Create a button to publish to mqtt
I am new to HA and I am trying to create a button for the UI that when pressed, will publish to a mqtt topic.
I would like a push button on the UI to do nothing other than publish a value to an mqtt topic.
I have an instance of node red on another machine that will subscribe to the topic.
I have tried to create this through the button card config but I get an error:
UI editor is not supported for this config.
I tried it like this:
type: button
tap_action:
  action: call-service
  service: mqtt.publish
  topic: south_garage_door
  payload: "0"
show_icon: false
name: South Garage Door
Thanks for any help. I am sorry but I am very new to HA,YAML
You probably will have to create a script or shell command and call it from the button.
Like here:
https://community.home-assistant.io/t/mqtt-script-payload/211454/2?u=mcarty
Thank you so much for your reply! I see the example you sent. Can the script or shell command be input through the Button Card Configuration? or do I need to do that somewhere else?
After creating the script it will show up in the lovelace button card dropdown selection.
I see it now. Thank you so much! I am glad there are people like you willing to help newbies like myself! You got me on the right track now. I appreciate that you took the time to help me!
I know the topic is quite old, but for reference, if you use the button-card from hacs you can do the following to make it without creating a script:
type: custom:button-card
tap_action:
  service_data:
    topic: <TOPIC GOES HERE>
    payload: <PAYLOAD GOES HERE>
Maybe it would work with the built-in button card.
Works with non-hacs button card with MQTT integration:
type: button
tap_action:
  service_data:
    topic: backyard/lights/8
    payload: 'on'
