Create a Card on Lovelace that shows me the last time a door sensor changed it state
Hello everyone,
I want to create a card that shows me the last time my door sensor changed its state.
Everything I tried so far gave me only the state of the contact sensor (Closed \ Open).
I want to see the hour when it’s closed or opened, like in HA Demo:
Screenshot 2023-04-17 114704
I think you will need to use a template to extract this information as its not part of the entities attributes.
The template structure would be something like this:
{{ as_timestamp(states.binary_sensor.front_door_last_ding.last_changed)
| timestamp_custom ('%H:%M' ) }}
Changing the XXX part to marry your entity
states.binary_sensor.XXX_XXX_XXX.last_changed
However note that this method (and I dont know of any other, but there might be) will show the last changed OR the last time HA was started so wont always be an accurate representation.
To use this on the frontend you could either use the above template in a card that supports templates like markdown card for example or you could create a template sensor in your yaml files something like this maybe:
template:
  - sensor:
      - name: front door last changed time
        state: >-
           {{ as_timestamp(states.binary_sensor.front_door_last_ding.last_changed) |
You can use secondary-info to show the last changed time under the entity state.
https://www.home-assistant.io/dashboards/entities/#secondary_info
Yeah, I tried it, but this is not what I need.
I need to see the time (HH:MM).
:smiley:
Thank you! It works :slight_smile:
Hi, I’m new to this kind of advanced config in HA and want to achieve this exact same thing as @spjeny and I realise this kind of editing of entity cards isn’t possible in GUI.
Could you please explain how I get my entity details so I can enter it into the template you’ve described?
I can’t see it anywhere in the “Device info” screen for example: http://homeassistant:8123/config/devices/device/
