Create a card that cycles through a set of cards
I am rather new to Home Assistant and currently setting up my dashboard. So far, I figured out most of what I want using resources from here or elsewhere on the internet. But now I am stuck.
I have a couple of temperature sensors and want to have one card on the dashboard that cycles through the temperatures, displaying each (along with a name for the sensor) after another.
My first idea for implementation is to have a card that cycles through a list of cards, but I could not find any existing component for this.
Thanks in advance for any pointers!
These don’t flick through cards, they do allow multiple entities and have a graph! You need HACs for the first one. Stats one is built in. There may be a flick/shuffle card in HACs.
type: custom:mini-graph-card
HACs Custom card
type: statistics-graph
This allows to show card under conditions, you could stack them so they stay together.
Conditional Card - Home Assistant (home-assistant.io)
I was thinking about suggesting the conditional.
Can you setup the condition to change on a tap action. Perhaps a script with a counter.
0 1 2 3 4 > repeat
Tap action increment script counter.
Thank you, HasQT and vingerha for pointing me in the right direction.
I set up an input_number for the counter and an automation with a time pattern that increments the counter. With this, I could use a conditional card.
A bit more complicated than I thought and with a lot of code duplication, but it’s working. Maybe I’ll move the logic into a template that provides the label and temperature based on the counter - that way I would not need all the conditional cards.
You could also add HACS card templater, adding template capabilities, but this not necessarily makes it less complex
Or even simpler: GitHub - bramkragten/swipe-card: Card that allows you to swipe throught multiple cards for Home Assistant Lovelace.
https://github.com/bramkragten/swipe-card/blob/41a735dba1f9e4f54e16810c83573ea14ab7fd1e/examples/images/preview-coverflow.gif
