I am running home assistant on a synology NAS which has a very nice GUI to manage docker instances and make it very easy to setup a domain name with SSL support (using cloudflare for certificates and the synology GUI for reverse proxy) and everything works super nicely
However it’s still very time consuming to create and configure docker containers for every addon I need
As I understood Hass.io is a complete system that cannot run within a docker container because it need to have control over docker to create containers every time you install addons
So what if we added a way to configure a docker api to manage docker in home assistant and this would make the addon section appear and it will use this api to manage all the docker containers it needs for the addons
Basically porting all hassOS functionalities to the docker api instead of linux deamons working in with commands, so we can get automatic update, addons etc
That would be a nice feature for all the docker enthusiast out there who run home assistant in docker
Nope HassIO doesn’t run in Docker, it runs docker
Home assistant is the one running in docker
So to run hassio you need to give full control of your linux install to some hassio utilities, which will likely not work if installed in the synology os (custom linux with a lot of commands and programs missing, doesn’t have apt etc, I tried never made it past step 1: install requirements)
However it might be possible to have nested docker installs and as such to run HassOS in a docker container that will hypervise it’s own docker
Although that might be very weird to manage if I need to access the command line and there is no docker image of this yet
I think maybe both correct. HassOS is the minimal OS that runs Docker. HassIO is a supervisor that runs in Docker but needs enhanced OS level permissions in order to control its Docker environment. HA runs in a Docker.
And yes, I run HassIO in Docker on top of Ubuntu. Which is why I think you might be able to do similar on NAS. But if the enhanced permissions aren’t available in the NAS os, then HassIO won’t be very functional.
I’m definitely very interested in this but really have very limited knowledge of how Docker and suchlike works I used to use HassIO on a Pi and now followed the tutorials to get HA running on a QNAP NAS Docker instance. It generally works really well but I do miss the extras that HassIO had!
