Hi I copied the code into config. Any suggestions?
several notifications
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2117, in forgiving_as_timestamp
return dt_util.as_timestamp(value)
File "/usr/src/homeassistant/homeassistant/util/dt.py", line 153, in as_timestamp
raise ValueError("not a valid date/time.")
ValueError: not a valid date/time.
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 633, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2735, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2120, in forgiving_as_timestamp
raise_no_default("as_timestamp", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1911, in raise_no_default
raise ValueError(
ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%H') }}' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 750, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 635, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%H') }}' but no default was specified
2024-12-03 20:06:07.687 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%H') }}' but no default was specified') while processing template 'Template<template=({{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%H') }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.heater_end_time_hours'
2024-12-03 20:06:07.688 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%M') }}) renders=2>
raise ValueError(
ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%M') }}' but no default was specified
homeassistant.exceptions.TemplateError: ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%M') }}' but no default was specified
2024-12-03 20:06:07.689 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('ValueError: Template error: as_timestamp got invalid input 'unknown' when rendering template '{{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%M') }}' but no default was specified') while processing template 'Template<template=({{ states('sensor.heater_end_time') | as_timestamp | timestamp_custom('%M') }}) renders=4>' for attribute '_attr_native_value' in entity 'sensor.heater_end_time_min'
2024-12-03 20:06:07.691 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ (states('sensor.heater_end_time_hours') | float * 60) | round(0) }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2354, in forgiving_float_filter
return float(value)
ValueError: could not convert string to float: 'unavailable'
