Create Action with Integration
Hi, i add an Integration plug-in called progettihwsw, this integration has the switch property to activate a relay, i simply want to create an action at 8.00 in the morning that activate this relay.
I go in “Settings” => Automation => create new automation button on bottom right => Activation and i select time 8.00 then in the Action i can’t find anything about the progettihwsw integration…
Please can you help me?
How i can find the progettihwsw integration and define the action to do?
Use the switch turn on service and specify your switch entity_id.
