I’ve run Home Assistant Core using Docker for a number of years on my server and recently I installed Home Assistant OS for my mother on a Raspberry Pi. From what I’ve read I can see that HAOS is using Docker for all the add-ons which is great.
There is a image on Docker Hub that I can’t to make into an add-on so I can use it on this new installation. However I’m a bit confused as to how to proceed.
I wish this was easier. It would be awesome to be able to spin up an add-on like I can spin up a container with docker-compose. My recommendation: reach out to one of the few large community repos, send them a few bucks, and put in a request. Alex at GitHub - alexbelgium/hassio-addons: My homeassistant addons seems like a great guy and is super responsive to new add-on requests.
It’s basically just a bash script but the Let’s Encrypt add-on that is available doesn’t seem to support domain alias for DNS-challenge which acme.sh does.
With domain alias I can have a subdomain which supports dynamic dns updates that I can point all my real domains to so I won’t have to add a TXT record for my domains.
Like this.
I have a subdomain acme.example.com which supports dynamic dns updates.
If I want a certificate for production.com I can just point _acme-challenge.production.com to _acme-challenge.acme.example.com etc.
By doing this I won’t have to enable dynamic dns updates for production.com.
acme.sh does share the Dockerfile on their git repo so I could theoretically make a HA add-on with this but I would rather use the main images so I could rely on the updates from Docker Hub rather than updating it myself.
Running custom docker image inside Home Assistant OS is not recommended and will probably disable updates (see quote below). Nevertheless, if you really want to do it, here are two ways:
Installing manually a custom container will modify your HA status to an unsupported/unhealthy state. You will be blocked from upgrading Home Assistant and upgrading any Add-ons you may have. Stopping this custom container will reset the normal status
So the better solutions is to try to find a premade HA addon for the docker image, create your own addon, or don’t use Home Assistant as you base OS and run it inside a VM or container instead on top of another system.
Modify as needed. ie, point build.yaml to the public image you want to use
Profit
One obvious pitfall is that simply pulling someone else’s ‘latest’ container could easily lead to broken installations. However, the alternative is setting up all of the CI to build and publish your image which can be non-trivial. Then maintaining it for…ever. I’m definitely going to go with option 1 until I’m sure that won’t work.
