How can i create an automation or a scene that prevents automations from running if i am going to be on vacation abroad?
Rather than an automation use an input select.
Give it options like: Home, Away, Guest Mode, etc… Put the input select on your dashboard so you can change it.
Then use the state of that input select in a condition in all your automations to determine if it should perform the actions or not.
great idea. just done it and it worked!
thank you.
