Hey everyone so using this write up here: https://home-assistant.io/components/sensor.template/ I see I can create a custom sensor and set its state. However I would like to create some attributes for this sensor.
My use case is I have a FedEx sensor for my wife and myself. I am adding up our packages and would like to make an attribute that says one of them is in transit one of them is out for delivery etc.
Hi @arsaboo I believe I did create a custom sensor. I’m just looking to add additional attributes to it. Right now I can only set the state of the sensor (so 2 or 3 etc. however many packages are out for delivery). I want to create an additional attribute say something like package_state.
So the config file would look something like this:
custom_sensor.package_state = {{sensor.fedex.attribute + sensor.fedex2.attribute}}
From my understanding, the doc doesn’t mention anything about creating custom attributes for template sensor. It just shows how to take attributes from other sensors to apply in the template sensor.
I also need to create custom attributes into some template sensors.
# python_script.set_state to display whether life360 are overdue or not
# triggered by automation.life360_connected
# https://community.home-assistant.io/t/life360-device-tracker-platform/52406/267?u=mariusthvdb
entity_id = data.get('entity_id')
if not entity_id:
logger.error('No entity_id provided')
state = data.get('state')
if not state:
logger.error('No state provided')
if entity_id and state:
# old_state = hass.states.get(entity_id)
# if old_state:
# attrs = old_state.attributes
# else:
# attrs = None
theme = 'red' if state == 'on' else 'green'
friendlyName = entity_id.split('.')[1].title().replace('_',' ')
hass.states.set(entity_id, state,{
'custom_ui_state_card': 'state-card-custom-ui',
'friendly_name': friendlyName,
'device_class': 'problem',
'theme': theme,
'show_last_changed': 'true'
as you can see I use custom attributes, in fact you can set anything you want. In this script and automation even the (binary_)sensor itself is ‘created’.
Another question for the community - looking for a good custom component example that shows how to add an input_number to HA. For example, I’m creating a CC that calculates a number of thermal comfort parameters - those require inputs of physical insulation properties (these are estimates, or more like tuning parameters). Is there a way I can have those created at the same time the CC is instantiated? Now that I’m thinking a bit more about it, I know I can create entities on the fly in appdaemon using the hass.set command. I’m going to give it shot, but has anyone done this with a CC? Thanks!
That didn’t work… Now I’m trying this within the __init__ function:
input_numbers = ["input_number.htc_test"]
dev = []
for input_number in input_numbers:
dev.append(InputNumberClass(input_number))
add_devices_callback(dev, True)
