Nevermindā¦ it seems it has been reverted for now
Reverted because it needs a new supervisor. It wasnāt backing up for the last few days (reverted in 2021.8.0b5)
Itās comingā¦
Ok then back to my original request
Agreed. Iāve noticed the deprecated status in the logs tooā¦
While it gets done, you can do it also in the config\blueprints\automation\vorion\create-automated-backups-every-day.yaml
Line 39
change
- service: hassio.snapshot_full
to
- service: hassio.backup_full
P.S. I did not want to copy that stuff and create a new blueprint as this would take away vorions credit
Wondering if it could be possible to also delete previous snapshots if all went well.
Hi, i get an often the following Error. What could it be?
Logger: homeassistant.components.automation
Source: components/automation/init.py:646
Integration: Automatisierung (documentation, issues)
First occurred: 08:08:19 (1 occurrences)
Last logged: 08:08:19
Blueprint Automated Daily Snapshot generated invalid automation with inputs OrderedDict([(ātrigger_timeā, ā24:00:00ā), (āsend_notificationā, True), (ānotify_deviceā, ā61840df3aa94bac80a6241014f744687ā)]): Expected HH:MM, HH:MM:SS or Entity ID with domain āinput_datetimeā or āsensorā @ data[āatā][0]. Got None
Nearly 2 months after the change from āhassio.snapshot_fullā to āhassio.backup_fullā and this is still not fixed? What gives? I did it in config myself but itās a 5 second fix.
I updated line 39 and now Iām getting āError while executing automation automation.automated_daily_snapshot: Unable to find service hassio.backup_fullā I thought that was suppose to fix this. Any thoughts?
Is it possible to move the backup automatically to another location?
Iām running HA OS on a raspberry and want the backup be moved to my NAS
I use samba backup as the second post of this thread and it works perfectly
in the original blueprint is no longer available and probably has to be hassio.backup_full
I am also using samba backup though, offloading the backup to a NAS.
Interesting topic. Is there also a way to automatically restore a back-up? My plan is to create a second home assistant instance as a back-up. I currently run my primary home assistant on a VM on the Synology. Iāve faced some storage pool issues in the past which led to downtime of HA.
I have a second instance of home assistant on a Pi in the same network. Restoring a back-up from the primary instance to the Pi worked like a charm. But now I would like to automate it that during the night the secondary HA is automatically restored with the back-up from the primary.
Any thoughts?
I just saw this as well I just select submit and it said it fixed the workflow. Just scheduled it to run in 10 mns so Iāll confirm that it works in a bit.
Did it work?
Nope Iām still getting the error and the automaton does not work with
2022.9.1
